notsed
Everything posted by notsed
  1. i have one off an 03, its in good shape i just need to make sure i have all the parts, 30 shipped
  2. i got one a while ago ran it for 2 years no problem, just got that exact same one a few months ago, no problems yet...
  3. could be like said above most likely, but maybe converted to run dc also
  4. ive never had a tranny work smooth on a bench, if everything is in good shape, no bent forks etc, i should work fine when you put it together
  5. No i but i havr an rm adjustable plate i could sell with it
  6. m10x1.25, same as the foot peg bolts, might be hard to find locally, i would order some online like here http://www.ebay.com/itm/2Pcs-Fine-Thread-Hex-Cap-Screw-Bolt-M8-x-1-M10-x-1-M10-x-1-25-/120813211809?pt=LH_DefaultDomain_0&var=420052393156&hash=item1c210750a1
  7. did you decide you dont want yfz arms anymore? just save up 400 and get full flights instead of wasting your time along with others.
  8. make an offer, i need to sell these, other jets available
  9. for mine i ran all the grounds together then to the battery and i ran the pos to a toggle switch then to the lights. the yellow/red wire is a trigger for the built in relay in the regulator, you gan hook it up in a way so the lights come on when you start and then stay on for a period of time after. it can also be set up to only charge the batt when the lights are on and also run lights with no batt, youd have to look on their website for different configurations
  10. you guys are dicks lol, give the guy a break
  11. in good condition 2003 oem stator-100 shipped http://api.photoshop...ditions/256.jpg
  12. notsed
    oko jets
    just so you know if you need jets, they take the same pilots as pwk 28 and you need keihin round main jets
  13. ive got a stator of an 03 just switched for a 200w, works good, square plug. 95 shipped lmk if you need pics. i can send them to your e mail
  14. 70 shipped also has a newer choke so you dont have to hold it
  15. I have a set of stock carbs i need to let go. tors removed idle screws installed, 360 main, 27.5 pilot, dynojet needles and a thottle cabe that still works but has come apart at the steel 90. They are in good working order, they came off a good running bike just switched for 34's Asking 80 shipped, lmk if your interested and ill txt or email you pics, 519 564 0550
  16. its rather simple, figure out what you want to keep or not and trace the plugs you dont want like tors and light back to where they tie in and cut them out.
