sounds like the carbs are completely out of sync. get those babies dialed in and you should be good to go! Have fun :biggrin: and also, welcome to the HQ
I will try to straighten it out with a long pipe.Hopefully everything goes back in place. I heard that there are companies that build rear subframes.Anyone know about these?
Throttle stuck W/O and the bike took off and flipped end over end and back on its wheels and shut off.(Good thing) Anyways crushed the front bumper and busted the rack off the back.It bent the 2 pieces that hold the rack 45 degrees up. Is there a good way to fix this? Anyone done that before? The piece that holds the rear fender down also is bent up a tad. Thanks guys!
Go ahead and pull the clutch cover off and see what is going on.Does it do it when its running? Could be the kicker return spring mechanism rubbing on something.
1st you need to find out where its leaking from.Is it coming from the gasket or the drain bolt? To remove the cover just drain the fluid and pull the kicker, remove the bolts and the cover comes right off.You may have to remove the footpeg and healguard.Its pretty self explanetory. Good luck!
Are you getting the filter wet?I pressure wash mine also and fires right up.Water may be getting an electrical connector wet also. They make spray,I think silicone spray,that makes connections water resistant.Try that. And don't get your filter wet.
