f4istunna
Everything posted by f4istunna
I have quite a few sets of wheels and tires ive accumulated over the years. Tons of 50% and under tires id be willing to give free for pickup NE ohio or west pa, or just cover shipping and paypal fees oems, cpl turf tamers, holeshots, i think razrs etc. Several sets of like new oem rears, kenda fronts $40 a pair Have oem front wheels w/ razr tires 60-70% $75 oem rears w/ 70% kenda klaws $80 itp? douglas yamaha front and rear banged up but hold air good spares $20 a pair I have pics of a cpl sets if anyone interested thanks
i have quite a few extra sprockets. Ill go look what sizes, ill them all (few front and few rears) for $20 or so Also have a new set of oem oshtu's 20/9 $45 plus the ride.
black/chrome powermads w/ mounts $35
I agree w/ everyone else. In most cases ive had like yours a simple adjustment took care of the problem
sent pms
carbs and airbox Sold setup a few auctions tonight. Still alot left
I have a set in good shape w/ good boots no more than $25 shipped maybe a cpl bux less depending where you are pm me if interested thanks
Hate to sell it, had alot of plans for it but dont really have the extra time or money to build it the way i planned. Plus could use the money elsewhere 05 yfz. It has several brand new (never ridden parts) other than around the house a cpl times new G force +4 axle Asr + 2 a arms chain and sprockets trailtech fatbars w/ yfz logo clamp front tires used raptor 700 stem (+3/4) douglas rear 8" beadlock w/ 18" razr front itp wheel w/ new dunlops ac bumper 06 crank and cases extreme propegs anodized black Extras Blue full plastics stock axle gas tank stator and misc engine parts stock stem and bars Propegs wheels and tires etc I have receipts for alot of work done low hours on motor. Starts runs and rides good Only flaws are it currently leaks gas from carb while running (im guessing floats are sticking) I should be able to get it fixed later this week. And if it sits for more than a week it will have a drip or 2 of oil under it. Im not sure where its coming from i looked and couldnt tell where exactly but looks like sidecover gasket. Ill look into fixing that also Looking to get $3000 obo for everything Located in NE ohio can meet or deliver within 100 miles if asking price met, or possibly further if buyer pays gas. Thanks for looking
bump, going to list some of it on ebay in the next cpl days. Anyone interested in anything else first? Thanks
Do your cases leak now? If not why not use em? Id say at least half of the shee's out there (at least ones ive seen) have the chain damage and still going strong. I have a set that dont leak but do have chain slap damage if your interested
im in ohio, but i have a set of stock front shocks w/ the pink color springs you can have free just pay shipping. One is slightly bent. I still used as is and didnt notice until i took them off.
under 24 hours left on my auctions if anyone is interested. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...T&viewitem=
i have a set 64mm, stock porting. One cylinder is scored a little but nothing too bad, hone may take care of it. comes w/ pistons if you want em. $185 shipped
Stator w/ adjustable plate sold set of engine cases and thumb throttle sold also but i have 1 more set of cases and 2 throttles still. - Engine cases w/ side covers normal chain slap damage to left no leaks, cracks $95 - Oem swingarm could use paint or pc bearings seemed good $25 - Oem gas tank w/ petcock and cap $20 - Kicker lever good splines $20 shipped - Kick shaft w/ spring, gear, bushing Good splines $17 shipped - Trans main & counter w/ all gears, c clips, bearings, sprocket nut... $100 shipped - Complete clutch - basket, hub, plates, rod, springs etc. 1 spring bolt missing but i should have one for it, plates show wear but still good life left $50 shipped -oem steering stem w/ 7/8 barclamps, and mounting clamp/bushings $30 - Rear wheel hubs good splines $40 shipped - Front Brakes complete master/lever, lines, and calipers w/ 60-70% pads $65 shipped - oem Spindles w/ guards $30 shipped - Oem axle cosmetic wear, good splines and threads $30 - Rear brake m/c w/ lever, resivior and lines $35 shipped - Pipe hangers $17 shipped - Front fender brackets $17 shipped - Front hubs w/ rotors good shape, straight rotors, bearings feel good. $50 shipped - Radiator no leaks w/ overflow bottle and hoses $20 - wire harness cpl cut wires but ends still there to work w/ headlight switch housing switch is missing a peice inside but rest in good shape no cdi or coil $35 shipped - Shift mechanisms shift drum/forks, star, shift shaft and shifter lever etc $30 shipped - F & R sprockets w/ sprocket hub 41t and 13t good shape $20 shipped - Engine mounts $17 shipped - Seat needs recover (hole) and foam repair or replace good pan and latch $15 - Front shocks yellow springs need cpl bushings $20 - Rear shock linkages $17 shipped - Stock axle minor bend on right (only noticed down the road in high speed) $10 - Stator w/ adjutable timing plate (meter tested good) quad bought needing rebuild then torn down so never tested. Red wire cut and was inline crimped in place. end still intace could be soldered $55 shipped SOLD - Seat Gray cover nice shape w/ latch $40 - Cylinders 64mm stock porting untouched, left has some scoring nothing major. right had over 100psi left around 60psi should be bored but a hone might do. Pistons come with $175 - Full chassis skid w/ all bolts and clamps $50 - Ac grab bar one taillight tab has jbweld, not cracked all the way through just the tailight bracket the rest is in good shape $15 -Ac front bumper polished bottom pushed in a little from nosedive mounts up good and hard to tell on quad. $15 - Mikuni Stock carbs w/ tors and cables $60 shipped - White front shocks w/ bushings $20 - Pro Armor Nerfs polished w/ black nets (nets fit but extra peices towards frame taped up) straight $50 - Spindles $30 shipped - Clutch lever/perch w/ cable and ebrake cable $20 shipped - Front hubs w/ Rotors straight no grooves need bearings $45 shipped - Stock pipes and silencers sanded and painted high temp black $50 - Stock metal footwells $10 - A arms silver straight, normal paint wear on lowers good balljoints and boots come w/ tie rods $90 - Radiator w/ overflow $20 - Wire harness no components good shape $25 shipped - Rear Brake Caliper w/ mc lever, brake line and resi, good pads if mem serves $60 shipped - Stock airbox w/ lid and foam filter $30 - Headlight/run switch $25 shipped - Stock head very minor buildup on one dome other one mint $25 shipped - Thumb throttle $25 shipped - Tie rods w/ good ends and boots $15 - Stock footpegs worn but still grab $20 shipped - Oem rear wheels straight normal wear on lips $45 - Oem front wheels straight w/ wear on lips $45 ($80 for all 4) - Like new kenda front tires 22/7/10 (short 22) $30 - Oem clutch perch/lever w/clutch cable $17 shipped - Carb caps w/ tors good wiring $15 shipped - ignition switch w/ key $25 shipped Few things you guys can have free if interested just pay shipping - stock airbox cut out (completely open) w/ uni filter - white rear shock spring stock - stock crank needing a rod bearing - pink front shocks ( 1 is bent) Have white full fender, and white race cut plastics, 01 frame w/ title 2 dents in front from bumper straight, 97 frame bill of sale. Local only on the frames and plastic sorry. also have quite a few sets of misc 7/8th handle bars $5 a peice have one peice design and crossbar type. If you'd like to see pics of anything just ask. Ill post up more when i get time also.
Ill have to box up the cases and check shipping to your zip to get a better quote. I guesstimated the weight and size and looks like around $30-40 w/ ups tops probably a little less. You can have the 3 for $150 + whatever actual shipping is. Ill get the cases in a box and send you a msg w/ shipping price. thanks
have it all, sent you a pm. Id also be willing to trade some parts for a 250r stock carb and reeds, could use a shee coolhead too
got it! Will be shipped within next cpl hours Thanks
sent a pm i think i still have another stock crank w/ broken rod too unless i scrapped it you can have if you want
I havent ridden in sand much but in the woods/fields ive ridden on quite a few different setups. Ive always liked axis and tcs and works the best. I agree on getting the rear done also makes all the difference. By the way anyone here have a gt thunder rebuild rear? Just curious how they perform on thegeometry of the banshee. I had laz do my raptor and wifes 400 rear shocks and couldnt be happier
Also have some auctions going w/ about 3 days left if anyone is interested heres one of them just click other items http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=220296922861 All Parts Will be Shipped by Next Business day
I listed all these parts in my other thread for the toomeys, They sold and i realized the title only said toomeys for sale and didnt see link to edit the title. Sorry for the repost. Prices are + shipping unless posted shipped. Will deal if you buy a few things. I can accept paypal or money order whichever is easier for you. Have pics of some of it still have to get pics of some. All parts are in working useable condition unless stated, used w/ normal wear. All from 95 or newer quad. Most from the 97 or 01 . NE ohio near youngstown if close feel free to pick up. - Engine cases w/ side covers normal chain slap damage to left no leaks, cracks $95 - Oem swingarm could use paint or pc bearings seemed good $25 - Oem gas tank w/ petcock and cap $20 - Kicker lever good splines $20 shipped - Kick shaft w/ spring, gear, bushing Good splines $17 shipped - Trans main & counter w/ all gears, c clips, bearings, sprocket nut... $100 shipped - Complete clutch - basket, hub, plates, rod, springs etc. 1 spring bolt missing but i should have one for it, plates show wear but still good life left $50 shipped -oem steering stem w/ 7/8 barclamps, and mounting clamp/bushings $30 - Rear wheel hubs good splines $40 shipped - Front Brakes complete master/lever, lines, and calipers w/ 60-70% pads $65 shipped - oem Spindles w/ guards $30 shipped - Oem axle cosmetic wear, good splines and threads $30 - Rear brake m/c w/ lever, resivior and lines $35 shipped - Pipe hangers $17 shipped - Front fender brackets $17 shipped - Front hubs w/ rotors good shape, straight rotors, bearings feel good. $50 shipped - Radiator no leaks w/ overflow bottle and hoses $20 - wire harness cpl cut wires but ends still there to work w/ headlight switch housing switch is missing a peice inside but rest in good shape no cdi or coil $35 shipped - Shift mechanisms shift drum/forks, star, shift shaft and shifter lever etc $30 shipped - F & R sprockets w/ sprocket hub 41t and 13t good shape $20 shipped - Engine mounts $17 shipped - Seat needs recover (hole) and foam repair or replace good pan and latch $15 - Front shocks yellow springs need cpl bushings $20 - Rear shock linkages $17 shipped - Stock axle minor bend on right (only noticed down the road in high speed) $10 - Stator w/ adjutable timing plate (meter tested good) quad bought needing rebuild then torn down so never tested. Red wire cut and was inline crimped in place. end still intace could be soldered $55 shipped - Seat Gray cover nice shape w/ latch $40 - Cylinders 64mm stock porting untouched, left has some scoring nothing major. right had over 100psi left around 60psi should be bored but a hone might do. Pistons come with $175 - Full chassis skid w/ all bolts and clamps $50 - Ac grab bar one taillight tab has jbweld, not cracked all the way through just the tailight bracket the rest is in good shape $15 -Ac front bumper polished bottom pushed in a little from nosedive mounts up good and hard to tell on quad. $15 - Mikuni Stock carbs w/ tors and cables $60 shipped - White front shocks w/ bushings $20 - Pro Armor Nerfs polished w/ black nets (nets fit but extra peices towards frame taped up) straight $50 - Spindles $30 shipped - Clutch lever/perch w/ cable and ebrake cable $20 shipped - Front hubs w/ Rotors straight no grooves need bearings $45 shipped - Stock pipes and silencers sanded and painted high temp black $50 - Stock metal footwells $10 - A arms silver straight, normal paint wear on lowers good balljoints and boots come w/ tie rods $90 - Radiator w/ overflow $20 - Wire harness no components good shape $25 shipped - Rear Brake Caliper w/ mc lever, brake line and resi, good pads if mem serves $60 shipped - Stock airbox w/ lid and foam filter $30 - Headlight/run switch $25 shipped - Stock head very minor buildup on one dome other one mint $25 shipped - Thumb throttle $25 shipped - Tie rods w/ good ends and boots $15 - Stock footpegs worn but still grab $20 shipped - Oem rear wheels straight normal wear on lips $45 - Oem front wheels straight w/ wear on lips $45 ($80 for all 4) - Like new kenda front tires 22/7/10 (short 22) $30 - Oem clutch perch/lever w/clutch cable $17 shipped - Carb caps w/ tors good wiring $15 shipped - ignition switch w/ key $25 shipped Few things you guys can have free if interested just pay shipping - stock airbox cut out (completely open) w/ uni filter - white rear shock spring stock - stock crank needing a rod bearing - pink front shocks ( 1 is bent) Have white full fender, and white race cut plastics, 01 frame w/ title 2 dents in front from bumper straight, 97 frame bill of sale. Local only on the frames and plastic sorry. also have quite a few sets of misc 7/8th handle bars $5 a peice have one peice design and crossbar type. If you'd like to see pics of anything just ask. Ill post up more when i get time also.
Toomey T5's w/ silencers $200 shipped
f4istunna replied to f4istunna's topic in For Sale - Parts & Accessories
Also have some auctions going w/ about 3 days left if anyone is interested heres one of them just click other items http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=220296922861 All Parts Will be Shipped by Next Business day -
