f4istunna
Everything posted by f4istunna
  1. i have a black gripper seat if your interested?
  2. i have some tires that would be good for studding if your interested you can have them just cover shipping. About 40% tread hold air
  3. $35 or $40 sound good?
  4. i dont live far from pa. Just tore my project down to partout though I have pretty much everything you need to build a complete shee other than pistons. Have good 01 bottom end complete, good 65mm cylinders, new gasket set. Chassis has fresh pc, let me know if interested im on oh/pa line
  5. i looked for the adjustable plate no luck ( i know i have one somewhere just have to dig). I found 2 stck stators and flywheels Proarmor nerfs still avail. pics arent the best i aplogize my lights sucks when the garage is cold lol
  6. i have 2 stock flywheels in good shape other than some surface rust that will clean up if anyones still looking? $25 ea ?
  7. pms sent 2001 ill let you know if he takes them asap thanks
  8. theres a guy ahead of you for the nerfs i just have to get some pics of them tonight or tomorrow. I do have an extra flywheel puller and should still have an adjustable plate w/ stator no on the lightened flywheel i have a cpl but they are all stock from what i can tell. Also only bumper i have left is the DG on the roller pictured
  9. I have alot of other stuff i was going to keep as spares too, damn near another complete bike. If you need anything not listed feel free to ask i might have it.
  10. Been thinking about it the past few days and with Xmas right around the corner and buying a new house this spring decided to part out my project shee also It'll be awhile before i can build it the way i planned anyway I didnt make a complete list yet but off top of my head -97 frame very nice, silver, good threads no damage -oem front wheels -Carbs w/ throttle cable Mikuni 28mm tors eliminate -Reeds with cage and spacers not sure model i beleive they are boyeson though (came w/ my motor) nice shape -Cylinders 65mm very minor marks ( i was planning on a light hone and use) lots of room to bore for future stock not modded or ported -complete 01 stock bottom end good shape everything but cyl and head Ran great -stock head nice shape -stock airbox w/ foam filter, lid good brackets and mount tabs -+4 axle (not sure brand, was in a parts bike i bought) its straight comes w/ carrier, sp & brake hubs w/ rotor and blaster? wheel hubs. needs the 2 smaller spacers to be +4 i never got around to making a set. painted black. -01 wire harness -black rad plastic w/ stainless flame inserts -Front hubs/rotors -DG bumper -FMF Gnarly pipes and pwrcoreII silencers like new chrome some minor bluing, silencers nice. One pipe has a small hole (about size of screwdriver tip) meant to have it welded but... I used them as is and it wasnt bad at all but should be patched up its on the front so wont notice repair when mounted (no need to rechrome) - black gripper seat w/ pan and latch -front and rear oem shocks (yellow)
  11. Ya the tank looks to be good, no leaks, fuel valve works. Headlight switch had a hairline crack about 1" or less that I plastic welded when i got the quad to keep moisture out. I rode with it all season worked good cpl small scuffs . Parcel post looks like $15 or so Priority is showing $ $39 (oversize and xcountry ) I can check ups too if your interested
  12. I have stock pipes and silencers you can have the pair for $40 pm me if interested thanks
  13. Chassis Skid SOLD thanks mike
  14. Guy i got the bike from told me pro armor, it had pro armor grab bar and nerfs too so im assuming thats what it is but im not 100%. Id do $55 shipped its in good shape w/ all the hardware plus its oversize so shipping is prob. $15-$20 let me know thanks
  15. parts in useable shape unless stated from 01 in good shape i bought it for the engine for my build. Can accept paypal or Money orders whatever is easier for you. Will ship within 24 hours of payment or next bus day on holiday/weekend. Plastics and frame are local pickup or meet only sorry. Located near oh/pa line and I80 - 01 Frame and swingarm w/ title- was going to keep for my next build but if i get $250 or so it can go :biggrin: 2 small dents from bumper in front tubes. no cracks or repairs - white full fender plastic f & r no cracks or bad scratches. looks like ink or paint was spilled on should clean up $35 - 97 frame good shape no cracks or repairs, could use repaint/powdercoat $100 - Eyeball headlight covers $10 - Full alum. chassis skid w/ all clamps/bolts nice shape $45 -AC polished nerfs, black nets bars in good shape, looks like wrong nets installed but they work just extra straps that are taped up. $35 - Front wheel hubs w/ brake rotors nice shape $35 - Clutch perch/lever w/ clutch and ebrake cable $10 - oem a arms good shape no dents or cracks, good balljoints come w/ caps, bushings and bolts. Have paint wear to lowers $85 - Shifter $2 - Wire harness (no cdi or coil) $25 -taillight w/ mounting bracket $10 - coil - good spark $10 - Headlight / kill switch oem $10 - Radiator w/ overflow bottle $15 - oem rear shock links $5 - Tie rods w/ good ends straight $15 - Gas tank w/ cap and petcock valve $15 - Stock exhaust pipes and silencers $40 - Rear brakes, Caliper, lines master cyl, lever and resivior 50-60% pads $35 - Front brake calipers with lines pads are worn $30 - spindles $15 - kicker shaft w/ springs and gear good splines $10 Thought i had more pics on my cam but ... Ill get some more pics of everthing this week
  16. i have a pair one is slightly bent the other is straight you can have both for $20 and whatever shipping is (im in OH) should be under 20. They hold air good and hard to notice the bend on the one unless on pavement. I just have to dismount the tires, i can do that today
  17. i have a rear master w/ resi, lines and lever for $25 + probably around $10 or less for shippijng. shoot me a pm if interested. I dont think i have a pic but i can try and get one of need be. thanks
  18. Thanks guys i appreciate the good words. Glad i could help you out.
  19. i dont think it will swap right over. I have a set of extra banshee hubs here and a spindle from my raptor Ill check them today if i remember and see if the hub fits over the spindle good. Im not sure how the calipers would line up either ill see if i still have an extra caliper laying around.
  20. f4istunna
    Coil
    i have a good one off my running 01 sent you an email
  21. i have a set of ac nerfs for $30 bars are good no cracks or dents, the nets are in good shape but look like they may go to a aftermarket peg w/ slots for nets. There are 2 extra straps (just taped up to the others now). I have a frame to but id prefer local pickup on that 01 w/ title
  22. f4istunna
    TIRES
    i have a set of like new oem rears for $40 and set of new kenda fronts for $40 if you take all 4 id do $70 let me know if interested thanks
