f4istunna
Everything posted by f4istunna
  1. Incase any of you are interested. I have about 20 auctions with banshee and raptor parts. More to come in the next few days when i get time. Most stuff is $10 w/ no reserve heres a link to the tranny just click other items to see the rest. Thanks http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=320307063043
  2. f4istunna
    Rims
    I have a cpl sets of extra stock fronts. They are straight w/ normal nicks/dings in the lip from trail riding. $50 a pair . Shipping shouldnt be more than 10 or 15 I just have to dismount the tires and ill get some pics.
  3. sent you an email i have a set in good shape other than the typical chain damage to the left side. No leaks
  4. I agree you should easily make your money back and be able to keep some parts if you want. I parted a cpl out over the past few years to build complete nice bikes I usually made my money back on the parts bikes and got to keep several parts i wanted for the build I just tore down a good running motor to sell seperate :: Shoulda threw it on fleabay whole
  5. I have all of it from a 95 in good working condition. Ignition switch w/ key and dash peice Headlight switch works good had small crack in bottom which was repaired w/ epoxy to seal it. wire harness has one wire that goes to the stator cut and spliced but the end is still in the plug and could be tied back in the plug if wanted. My wire was out of the plug on stators end so it was just wired in direct. (no cdi or coil) $60 shipped in the 48
  6. f4istunna
    wanted misc parts
    i have all of it if your still looking. Carbs Swingarm and carrier $100 ? Swingarm needs paint stripped or blasted and recoated. I have another swinger w/ nice paint (black) if youd rather have that for a little extra?
  7. Alot ending on ebay tomorrow. Ill make an updated list. Bottom end is seperated. Good trans, clutch good but some wear, crank, cases (normal damage from chain no leaks).
  8. f4istunna
    Rear Wheel Hubs
    I have a stock set that is painted black. they look good $25 if interested
  9. I had the same thing happen to me in the past on a 400ex i had back in 00 or 01. Bought new cdi, coil and im pretty sure stator at the time. Still nothing. Took awhile and lots of frustration but ended up finding out the new cdi was shit. ITs rare but might want to check it out before you pull all your hair out lol. Good luck
  10. sorry to hear that man. A guy on yfzcentral got me for $400 for a bottom end. I had his local sherrif go to his house called day after day etc. got nothing but excuses and was told all i could do is small claims... He did the same thing to several other ppl too. It sucks. Hope things work out for you. If you have is info try to contact his local law and explain to them. Maybe it will scare him into a refund or your pipes...
  11. I have a cpl sets of stock a arms. Black good balljoints and boots i think a cpl bushings may need replaced (cheap on ebay) $85 Also have a set than need paint or powdercoat and one lower has a nice dent. Still seems straight though just dented the tube. $45 for all 4 they are good other than cosmetics pm me if interested thanks I have a set of stock shocks you can have just pay shipping (springs chipped pretty good)
  12. specialized i replied to your PM sent you an email MJV yep still have the stock head. One dome has some very very minor pitting in it. Bike ran great. Ive seen and used heads in way worse shape. Shipping will be $10 or less in the 48 states Pm me your zip and i can get an exact quote Rigid Ill be splitting the cases today. Flywheel and stator are already off though. Flywheel has some nicks in the lip but worked great for me, lights and everything worked as they should. One wire from the stator (red/white) is wired straight in instead of plug but the end is still in the plug and could be repaired fairly easy if wanted. I just never bothered since it was connected good w/ inline crimp. let me know guys
  13. no problem brother thank you!!
  14. Last chance before Ebay!! Gonna start listing tomorrow sometime
  15. sure do. I sent you the address Thanks
  16. $50 shipped for all? Let me know thanks
  17. Heres a list of most of the stuff. I have several boxes of spares left too that i still have to go through. I know theres another set of a arms, swingarm, shocks, etc. Cylinders/Pistons SOLD Pipes/silencers SOLD Bottom end cases, trans, crank etc Everything inside cases $400 Case broken at normal spot no leaks -Radiator $25 -Rear shock (white) $45 -front shocks (white) minor paint wear from covers $25 -thumb throttle $20 -Ignition switch w/ key and dash peice (dash plastic scuffed) $15 -Never used oem bumper $20 -used oem bumper $5 few dings - Front hubs w/ rotors rotors straight $45 -pipe hangers $10 -Clutch lever w/ cable (a/m) $5 -Set of 4 oem a arms nice shape good joints blue $100 -tie rods w/ ends -Spindles $20 -Front brakes Calipers, lines and master w/ lever $55 has like new pads -Rear brakes Caliper lines master w/ resi and lever $55 will need pads -Rear brake hub w/ rotor $25 rotor straight no abnormal wear - f&r sprockets w/ rear sprocket hub $20 -Axle carrier $35 bearings still felt good but have some hours -Oem swingarm blue straight $35 -Headlights $15 some scratches on lens but both worked good last time i remember using them - Headlight/kill switch $20 -Oem steering stem w/ stadard bar clamps $35 straight -Axle (small bend at end on brake side) I used it as is all season, only noticed on the roads $10 if anyone wants it -Seat w/ new gray cover pan and foam good $45 -white plastics front cut blue hood and tank cover $75 no cracks -Stock intake/airbox w/ lid w/ K&N filter $35 filter used but still some life left -Carbs tors eliminated $40 -Oem grab bar w/ tail light Some minor wheelie wear straight no cracks $10 -Stator $40 (red/white wire pulled out of connector) I just used an inline crimp but could be repaired in if wanted the end is still there -Oem flywheel minor surface rust in spots, few dings on the lip Didnt seem to affect anything the bike ran awesome $30 -Reeds w/ cage and xover tube $25 (not sure brand got them w/ quad , good working shape) -Complete Clutch $45 basket/ gear on out w/ bolts springs etc. Clutch worked great no slipping or abnormal noises. Basket showing a little wear aswell as fibers but still plenty of life) -kicker lever good splines $20 Im sure i skipped or forgot some stuff feel free to ask if you dont see it wheels/tires I have alot ill be adding over the next cpl days. Im gonna clean my shed and garage out of some of the extra wheels and tires Douglas polished 8" yam rear $85 W/ 85+% 20" holeshots $120 Oem front yamaha wheels normal lip scuffs/dings $60 All parts will be shipped by next business day after payment made. Paypal or money orders. Thanks
  18. I tried to upload pics several times (reszed at image shack) w/ no luck. If you'd like to see pics of anything please send me your email address and ill get them to you asap Hauser How about both pipe hangers and both rad. supports $25 shipped
  19. i think i have 2 of them ill double check if so you can have it for $10 or so
  20. I had a chance earlier today to snap some pics of parts already off. Ill get them posted as soon as i get back from dinner :biggrin: :biggrin:
  21. Pipes Sold Thanks derek
  22. Cylinders and pistons SOLD thanks mpw Will have those shipped out early this afternoon for you exhaust is pending sale
  23. Need the $$ for a house, thanks for the offer though. deisel replied to your pm
  24. I have heard good things about castor from alot of ppl. Ive always ran Klotz in all my 2 strokes 32:1 w/ good luck. Is there really a noticable difference between any of the better oils?
  25. thanks priced to sell. I like to try and give good deals on the forums. paddleboy I dont think i have anymore case savers but ill look tomorrow, i beleive the waterpump is stock ill check that tomorrow too. carl ill get some pics to you asap mp pm replied w/ paypal info Its ashame these things have to be parted out to sell anymore. Ive been seeing them more and more on Craigslist around $1500 and under in nice shape and dont look to be selling (relists) . I Remember when non running parts bikes were more than that lol.
