f4istunna
Everything posted by f4istunna
97 complete banshee partout
f4istunna replied to f4istunna's topic in For Sale - Parts & Accessories
whats left prices cut.... Engine cases $50 upper good, lower has been repaired No leaks kicker gear good $5 shift shaft $5 coil $10 spindles $30 rear wheel hubs $30 right side engine cover (clutch) $10 aluminum grab bar $20 font wheel hubs/rotors $20 rear brake hub and rotor $10 stock radiator $10 gas tank with cap/petcock $10 seat $25 If anyone is interested in taking it all off my hands id take $125 for everything + shipping -
heres whats left i put it on ebay. Not listed on there yet are the frame and seat. Frame is local pickup (willing to meet within reason) I can ship the seat. I can let it all go cheaper outside of ebay... just post or pm if interested in anything. http://stores.ebay.com/RK-Cycles/Yamaha-BANSHEE-/_i.html?_fsub=497189015&_sid=141304705&_trksid=p4634.c0.m322 -
Ok heres what i have left to sell. - Stock ignition coil good spark $10 - Stock swingarm with axle carrier, bearings seem good could use painted or pc $35 - Left and right stock spindles. Straight with good threads $30 - Stock rear wheel hubs (pair) $30 good studs and splines, lugnuts included. - Aluminum rear grab bar Not sure the brand straight and solid $20 - Front wheel hubs and rotors (pair) Rotors have some minor wear but are straight and useable, good bearings. Could use paint or powdercoated. $20 - Rear brake hub and rotor Rotor straight hub looks good $10 - Engine cases upper and lower. Upper great shape, lower has been repaired, no leaks, good studs/threads. $75 - Stock radiator no leaks, has a few fins flattend out here and there $10 - good kicker shaft with spring/bushing $5 - Stock gas tank with petcock and cap $15 - Complete clutch pack basket plates springs bolts ... $60 - good shift shaft $5 -case saver with bolts $10 - stock shifter $5 - Jugs 68mm. they will need a few studs repaired/helicoiled bores look good no scars or damage aside from normal wear, a crosshatch hone and should be ready to go. they are port/polish . not sure what to ask so accepting offers.... - Stock frame straight and solid, has pegs welded to it and needs painted $50 local pickup only or will meet up within reasonable distance - seat good pan, foam and latch, im prety sure the cover is in good shape too but i need to get in the garage attic and dbl check it to be sure ill get it down and smap some pics when i do. -
no actually a guy locally saw my craiglist add came and bought all the lsr parts yesterday cash in hand sorry guys -
Lsr a arms, stem and axle are SOLD.... -
fireman and bigblock sent you emails with pics of a arms. -
UPDATED LIST REDUCED PRICES. I have pics of all the parts just post or pm your email and ill send them. I tried a cpl times with image shack to upload the new ones i got and couldnt get to work. - Lonestar extended axle. some surface rust but axle is straight, good splines and threads. Comes with 2 1" spacers, stock locknuts. Measures 39" end to end. $110 -Extended a arms standard travel beleive they are lonestar but not 100% sure they have heim joints straight and solid lowers are 16" fron center pivot to center bj stud uppers are 13" $150 black arms, chrome tie rods. Could use new paint or Pc - Complete rear brake system. Caliper, stock line, master cylinder lever and resi. Brakes worked, no leaks. Lever could use painted. $80 - Stock ignition coil good spark $10 - Kicker lever and knuckle still seems pretty tight. $20 - Left and right stock spindles. Straight with good threads $30 - Stock rear wheel hubs (pair) $30 good studs and splines, lugnuts included. - Aluminum rear grab bar Not sure the brand straight and solid $20 - Front wheel hubs and rotors (pair) Rotors have some minor wear but are straight and useable, good bearings. Could use paint or powdercoated. $20 - Rear brake hub and rotor Rotor straight hub looks good $15 - Engine cases upper and lower. Upper great shape, lower has been repaired, no leaks good studs/threads. $75 - Stock radiator no leaks, has a few fins flattend out here and there $10 4 Mil crank with 2mm spacer plate for base of jugs looks to be vitos crank with short (110mm rds) (has Pc stamped on it) true and welded good shape $275 - stock stator w/ pickup works good $60 - stock rear shock $60 -wiring harness with stock cdi harness has a few ends cut off but main plugs are intact $40 - good kicker shaft with spring/bushing $5 - good shift shaft $5 -case saver with bolts $10 - Modquad head with 22cc domes, head has 2 bolt holes that will need repaired (prev. owner tried to put bigger bolts in jugs instead of helicoiling the right way and cracked the inside edge of 2 bolt holes. Easy fix for good alum welder fill and drill out. make offer - Jugs 68mm will need a few studs repaired/helicoiled bores look good no scars or damage aside from normal wear, a crosshatch hone and should be ready to go. port/polish not sure what what type. make offer - Lonestar antivibe stem with std. size lsr barclamps didnt have a stock stem to measure against i beleive this is +1 its 24" from center of steering/tierod flag to center of bar mount. chrome nice shape $130 - Stock frame straight and solid, has pegs welded to it and needs painted $50 pickup only http://img94.imageshack.us/g/1048603j.jpg/ http://img94.imageshack.us/img94/4615/1048603j.jpg axle http://img843.imageshack.us/img843/4134/1048605.jpg axle http://img220.imageshack.us/img220/5531/1048594.jpg exhaust http://img841.imageshack.us/img841/7192/1048596.jpg exhaust http://img835.imageshack.us/img835/1504/1048568.jpg carbs http://img560.imageshack.us/img560/1281/1048562.jpg carbs http://img295.imageshack.us/img295/8738/1048561.jpg rear brakes http://img840.imageshack.us/img840/7408/1048541.jpg kicker http://img266.imageshack.us/img266/7409/1048623.jpg front shocks http://img826.imageshack.us/img826/2623/1048627.jpg radiator http://img269.imageshack.us/img269/3931/1048632.jpg grab bar http://img198.imageshack.us/img198/9513/1048642.jpg airbox/pro flow -
airbox sold thanks trick2stroke Firemann the swinger is stock not sure what brand a arms are sadly i stillhavent had a chance to get to the garage to get pics of them, i was pretty sick for a few days and been busy catching up w/ work since then. I still have to take 2 of them off the frame the bolts were seized i soaked them w/ pb so gonna go try and pull them off and get pics as soon as i can. no shorty levers sorry. has stock front lever and had a asv clutch lever but i used it on my Cr. Bigblock im gonna email you a cpl bigger pics of the rad. heres the link to ebay auction (ill take it off and sell to you directly if you want it so can give you the better price ) http://cgi.ebay.com/ebaymotors/YAMAHA-BANSHEE-YFZ-350-STOCK-RADIATOR-COOLING-w-CAP-_W0QQcmdZViewItemQQhashZitem5add432df1QQitemZ390259224049QQptZMotorsQ5fATVQ5fPartsQ5fAccessories -
pm replied Pro circuit pipes are sold AK sorry i didnt get any pics yet ive been feeling like shit the past cpl days w/ a bad cold so havent been out in the garage . Ill get out there and take some pics asap though. -
thanks T_shee AKheathen Ill get some pics of them this weekend then you can shoot me an offer if interested. Sound good? -
cylinder bore looks good but will need some studs helicoiled. I havent had a chance to measure the bore size yet. -
yep 4x115 rears. Replied to your pm. -
I need a few parts for a early model banshee 4mil build
f4istunna replied to SkinInd_Banshee's topic in Wanted
i replied to your post in my thread. i have the hubs and coil for you. might have an extra flywheel puller too ill have to look. I know i used to have 2 of them at one point in time. -
Bought this bike early this summer and havent had a chance or much extra $$ to do much with it. It ran when i bought it but low compression on right side. Tore down and found the modquad head have a small chunk missing around a bolt hole where someone put a bigger bolt to replace stripped stud. I planned on redoing the whole bike over winter and reselling next summer but its not gonna happen anytime soon we just had a newborn son and could use the money now so just decided to part this one out. Located near youngstown ohio if local feel free to pickup. I can ship no problem some of the parts are already boxed up and on ebay. Some i still need to find time to clean up and look over good before i list. Prices are plus actual shipping to your zip. If shipping i can accept paypal or money order. I will ship your parts by next business day at the latest after payment clears. -Pro circuit platinum pipes with silencers. Right pipe has half dollar size ding, one of the silencers has a loose or broken inner core you can hear it rattle. Im sure they need repacked. Pipes look good overall. I cleaned them up a little with steel wool but they will come out better with some elbow grease and polish. $150 - Keihin pwk carbs with thumb throttle and cable. I measure them at just under 29mm (28.80) so not sure if just considerd the common 28's or 29mm? Choke knobs work good, no stripped screws. Cable seems good. thumb throttle cover is missing 1 screw $150 - Lonestar extended axle. some surface rust but axle is straight, good splines and threads. Comes with 2 1" spacers, stock locknuts. Measures 39" end to end. $125 - Complete rear brake system. Caliper, stock line, master cylinder lever and resi. Brakes worked, no leaks. Lever could use painted. $90 - Stock ignition coil good spark $20 - Kicker lever and knuckle still seems pretty tight. $20 - Left and right stock spindles. Straight with good threads $35 - Stock rear wheel hubs (pair) $30 good studs and splines, lugnuts included. - Airbox with pro flow and KN Airbox has 1" hole on each side with screen, good lid and clamps. 1 damaged tab on box but mounts solid. K&N filter is well used but has some use left. Pro flow adapter in good shape. Intake boots included. $30 - Aluminum rear grab bar Not sure the brand straight and solid $20 - Front wheel hubs and rotors (pair) Rotors have some minor wear but are straight and useable, good bearings. Could use paint or powdercoated. $25 - Rear brake hub and rotor Rotor straight hub looks good $20 - Stock front shocks 14" red springs, good shape not blown. $70 - Stock radiator no leaks, has a few fins flattend out here and there $15 Thats all ive had time to clean up and get boxed up for now. Hopefully this weekend i can get to the rest. Frame looks good no cracks, needs paint or pc, the pegs are welded on , good engine cases, cylinders need a few studs helicoild i still need to measure bore, trans shifted good. Plastics are pretty rough, wheels and tires im keeping for my other one. good seat, Also have extended a arms not sure what brand . heres a link to some of the pics i have as of now. Will get pics of the rest asap. http://img94.imageshack.us/g/1048603j.jpg/ http://img94.imageshack.us/img94/4615/1048603j.jpg axle http://img843.imageshack.us/img843/4134/1048605.jpg axle http://img220.imageshack.us/img220/5531/1048594.jpg exhaust http://img841.imageshack.us/img841/7192/1048596.jpg exhaust http://img835.imageshack.us/img835/1504/1048568.jpg carbs http://img560.imageshack.us/img560/1281/1048562.jpg carbs http://img295.imageshack.us/img295/8738/1048561.jpg rear brakes http://img840.imageshack.us/img840/7408/1048541.jpg kicker http://img266.imageshack.us/img266/7409/1048623.jpg front shocks http://img826.imageshack.us/img826/2623/1048627.jpg radiator http://img269.imageshack.us/img269/3931/1048632.jpg grab bar http://img198.imageshack.us/img198/9513/1048642.jpg airbox/pro flow
i have a aluminum grab bar in good shape. i beleive its a AC $20 plus shipping shoot me your email ill send some pics thanks
i have a set on ebay with throttle id take $175 shipped if we deal outside of ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390258922424&viewitem=&sspagename=STRK%3AMESELX%3AIT
i have a good front master with lever and mounting clamp/bolts $30 shipped pm me if interested thanks
i have a stock one with zerk and good bearings $55 shipped
i have a full set bolts and brackets you can have for $20 + probably 5-8 for shipping depending where you are
sorry it took so long for pics, its a little dirty in pic but will be cleaned up before shipped.
$65 shipped sound good? sorry i didnt get a chance to get pics today, when i go to the garage tomorrow ill get some if you need.
Bore measures 64.4mm and its the right side. Stock porting. Ill get a pic or 2 here shortly i need to charge the batteries in the cam.
i have a set of cases from a 97 in good shape other than normal chain damage. Good bearing journals, no damage other than chain damage to upper half. Id rather not split up. Id take $100 or so for them let me know thanks
i have 1 cylinder leftover im pretty sure its right side. the bore looks good. Ill dbl check which one it is and measure the bore today.
I still have my stock pipe, i think the baffle is removed you can have it for $20 plus the ride if interested?
