375hp banshees
    209
Everything posted by 375hp banshees
  1. Caught somebody...don't know who
  2. Overseas ebay...I think
  3. Tru...but they dont, put it to good use ie inferior metals. But there is a BIG market for it.
  4. If they are , theyre not china, if they are, I wouldn't buy from them( vitos,bp...) ...anyway
  5. Vitos/rattlecanray duh
  6. ^^ Not you
  7. If it doesnt get easy after it breaks loose, its gonna Gall. Better stop lube/ soak & work back & forth ALOT.... & you might get lucky. Put piston up, on the cyl. Your trying & Check cylinders for metal after! .
  8. Cutting the nutsack strings finally...huh
  9. I wondered if that would...usually it wont start 2 find out
  10. If your slides are all the way down, do a leak down test.
  11. No head wont change port timing, base will. Either way, you need to follow up with squish measurement. And... 0's are important
  12. You even weld bruh
  13. Are you talking combustion area or water area( and not near oring surfaces). If combustion, as long as there arent pieces stuck in it, that could come loose, some will buff & reuse it. Is it worth it... not to me. Depending, it could create hot spots too. 1st ? Id ask is, is it from the current set up u have now? If so, you might have detonation issues that id address 1st!
  14. Looks that way shock, looks oe, just not bsnshee
  15. You look up to...eVeRyBoDy
  16. Sent from my SM-A505U using Tapaclark
  17. Check that air filter foam good, theyll deteriorate with age & fall apart, just by touching them. Make sure its good, so it doesnt suck all that foam in!
  18. ^^^ what him sayd... dis site sUx ... and no tYlErS small...and we dont like him
  19. Hard to tell in the pic, but there are drain holes in the case. Look at it from the bottom & see if its in line with what u r talking about. Most people discover it when carbs leak & it drips off of one of the bottom case nuts
  20. No sold'm all, to some Oregon feller. I'm sure he isn't using them. Maybe theyre still available?
  21. Choke help/ hurt? Got a timing light?
