bansheeseat$$
Everything posted by bansheeseat$$
  1. I would say you have an air leak or you are just way to lean.Do a leak down test before you tear it down again and then go from there.
  2. Sold!!! Pm ed you my addy
  3. Well I stand corrected,On both of mine I am unable to downshift without useing the clutch..Possibly because of the cut,Mine are 1-5 with N down so I'm assuming that is why.
  4. You must still use the clutch to down shift on a dunable or you will bend the forks at minimum.The drums are mot cut to downshift without useing the clutch.
  5. Get on ebay and get some.they are all over .
  6. Thats exactly what that is.You need to fix that before you get a bunch of dirt or whatever you ride in in the tranny.
  7. Yeah I cant see from the pics but look at everyone closely and I can tell that your basket and inner hub are worn pretty bad so it was time for a basket anyways.
  8. Pull your clutch cover off and inspect all the teeth on the drive and driven gear.It will be obvious when you see the chip/broken tooth.It's not the end of the world when this happens and it is a easy fix just yeah it sucks when it happens.
  9. On that note check your drive and driven gears.I have chiped a piece of gear tooth off and it sounds like a bad knock.I bet the piece of spring got inbetween the gears and chiped a tooth.
  10. I would defanently get a pingle for it and as for the bowls,I run the stock bowls and have no issues with fuel supply but I do run the dual pingle
  11. Yeah like you said not in the clymers but it was on my cd manual,I ran into lash issues a few years ago and was lucky enough to have it. Glad I could help you out.
  12. Drive gear Lash # A 90~98 Driven gear Lash # B 57~65 Lash Tolerances A+B 154~156
  13. Thats wierd,shows up fine on all of my puters.Maybe this one will work for you.
  14. It is showing on my side.What is showing on yours?
  15. This should help you out
  16. OMFG,Quick tell him there is a new double sided boost bottle now available for 3k more LOL
  17. I would deffanently go 4mil stock cylinder.I have a 4mil cub and a 4mil stock cylinder and once you do the 4mil stock cyl you will be very happy with it and I would bet a dollar that you will end up building a whole nother shee to do a 4mil cub.
  18. Something is still wrong with your compression #'s.With 18cc domes you should be more then 162 psi Unless your at 8000 ft above sea level.I run 18's in mine at 4500ft and have 185psi.
  19. A crank out of faze will do this also(Twisted)
  20. I got 12.5 into my 06 and that includes buying it off the showroom floor for 6k.I got 4200 into my 05 including the amount i paid for the shee.4mil stock cylinder I built for it.
  21. Thats a big problem,One being a banshee piston has a 13 degree dome and a 68mm blaster piston has a 9 degree dome.My sugestion to you would be spend the money on a aftermarket head and buy the correct big bore 9 degree domes for it.
  22. It doesn't matter what tire you have on it if there is no weight on the front nothing will turn good.Nature of have a shee.
  23. What linkage are you meaning?The dog bone from the banshee?If so yes.
  24. I should be there for a day,Probably saturday.I'll be at the drag hill as well.
