mouse
About mouse
  • Birthday 02/19/1974
Contact Methods
    colorado springs
    stock storke cheeta sheere out of frame same side +4 swing arm 35 carb on alcohal
mouse's Achievements
  1. i will be there friday 3 around 1 oclock till tuesday morning. just wondering if anyone else is going to be there that weekend. will be camping in the parking lot in tents driving a white 4 door gmc 3/4 ton pickup . hopefully see some people there.
  2. thankyou for the info
  3. got a 392 banshee at 92 horse. Its hard to shift into 4th gear and up when dragraceing. i was wonder how the duneable overrides are. ive had a regulare one and did not like not being able to down shift. thanks for the info
  4. you have a fly wheele
  5. you have a transmision for sale and how much thanks
  6. got polished clutch cover
  7. new top end vitos power pistions 19 domes and compresion is 110 in both cylinders is that to low elevation is 6000
  8. thonk you was just getting ready to go do the carbs
  9. the jetting was 158 main and 55 piolet the neddle was on 3rd clip and 2.5 turns out thanks
  10. looks real good and sharp
  11. moved from MI to colorado and need to change the jetting and was looking for a starting point. When it comes to jetting i hate it. The pistion i have are vitos power pistions and bore is 20 over if any of that matters THANK YOU FOR YOUR HELP
  12. Yes he fixed it up hes a pretty cool guy. Thanks for the quick reply mike and ill stick to the 18
  13. was wondering what size dome just moved out to colorado from MI. Ill be riding at 4000 to 6000 elevation. I was using 19 dome at 178 compresion and turbo blue gas. i have 17 19 and 21cc domes i have the power vitos pistions and dune and trail port by R B racing in MI. THANKS
  14. i havent seen them yet but there suposed to two into one exhuast pipe but if there in good shape i might put them on to just check them out. Thanks for your opions
  15. was wondering if DMC pipes are any good got a set coming from a buddy from MI. I got a set of t5 on right now and was wondering which one was better
