SAVAGE420
    19
Everything posted by SAVAGE420
  1. So fast i slapped yo momma.
  2. Ever wonder if your money's been down the butt crack of a stripper?? I bet now you do!! Hahaha
    1. Show previous comments  2 more
    2. So Cal Suspension
      So Cal Suspension
      All of my money has been in the ass crack of a stripper... I'm a stripper.
    3. jon321
      jon321
      JIMBOB for Canadian Prime Minister!!
    4. dirtydownunder
      dirtydownunder
      isnt that where its made ?
      "shake that money maker" and money falls out ?
  3. It's metal. It wont explode or bite you. Givver.
  4. Gree-hee-hee-heasy!
  5. Negative. Totally diff. Just order the proper reeds. Your sig is MASSIVE
  6. Never buy used shit. Nothing but problems. Buy new and you wont regret it. http://www.farmandsandtoys.com/partdetail.asp?partid=78 Cant go wrong here.
  7. It's the plastic gear that probably stripped. Simple $5 fix. Check the bearing where the impeller shaft rides for play and rust and what not aswell. Replace the bearing and seal the same time if needed. Cheap as well. Just a tip. When your done that get some grease in your fingers and lightly rub it all over the clutch cover and water pump gaskets. This will make it so they won't stick or rip when you take them off next time, + will help seal. I'm on the same intake, clutch and water pump gasket going on 4 years still like new never a leak or tear. Come off easy like butter every time and I've taken this motor apart plenty off times during this time. Don't do this to your base or head gasket. Do to water neck oring and the orings in aftermarket heads as well. Repack your kick start seal will grease as well since your clutch cover is off anyways. I blue lock tight the bolts as well.
  8. Yes you can. 26/28 has a 60mm bolt spread as well as 30/36 has a 60mm spread as well. 38/41's have a 70mm bolt spread. Good to go.
  9. Don't be a pussy. 50:1 FULL synthetic dominator.
  10. Jets or heli?
  11. Who would want to live in stupid BC??? PFFFF Dumb place.
  12. http://www.atvfourplay.com/New_%20Products-%20Soft-Bars.htm Don't ride other junk.
  13. Wack it off hard with a rubber mallet like you do in the lil boys room.
  14. Nope. Grab some Mikini or Lectrons if you want to switch back and forth.
  15. 138 to be safe. http://www.metaltechproducts.com/Chain_Calculator.htm
  16. Team "GO APE SHIT"
  17. Go ahead and bolt it up.
  18. Measure the smallest diameter of the throat where the slide goes up and down , use an inside Mic if you have one or can even eye ball it with a tape measure or what have you...
  19. http://www.albinoblacksheep.com/flash/posting Jesus.....
