macgillivary
Everything posted by macgillivary
  1. Hey picked up some parts over the winter and now installing them. Got some new carbs, but dont know where to start really with jetting them. Mikunis i know but I have little experience with Keihins. anyways its piped, trail ported, shaved head, 30mm carbs all at sea level. I got 158 mains right now and I think it was 55pilots in them, will have to check those again, havent finished assembling but just wondering if this is a good start for the jetting. Thanks for the help
  2. hey ill take it if you will ship to Canada i would pay the extra shipping
  3. sent you a pm
  4. using old pistons seems a little sketchy to me thats just asking for a broken skirt but glad to hear i wont need to bore
  5. did a compression test on my cylinders and with port work they are down to 90psi so im gonna rebuild her what i wanna know is when people do rebuilds on motors that didnt blow do they usually bore them or just buy a new piston kit the same size and put it back together without boring? or if its a judgement call how do you tell whether to bore your cylinders, mine are not scratched up at all they look good thanks
  6. thankyou that worked perfectly
  7. any tips on how to get them out, i need to replace them and am having problems getting them out are they pressed bearings? or just beat the crap outta them?? any help appreciated thanks
  8. macgillivary
    +4 axle
    hey im looking for a +4 axle if anyone has one they dont need anymore shipped to canada g force, durablue, lsr whatever doesnt matter leave or pm a price please
  9. i guess another question would be what is a durable mx tire too when i am not at the track i like to rip around the gravel pits and dirt pits I found with the turf tamers I was constantly tearing holes in the sidewalls from sharp rocks knarlys 4 ply or 2 ply?
  10. hey getting into some mx racing for next season so im building my shee over the winter on my last shee i ran turf tamers on hardpack to loose and they worked well but next year the tracks are raging from sandy, to loose dirt, with the odd muddy track after rain Anyways what would be the best tire for sandy loose dirt tracks i was thiking knarlys but i wanted to get some tips from you guys thanks, i know im going to get alot of answers but ill know my options better
  11. Well could be alot of things you say blown like is there a hole in the piston??? its burning up orings for some reason so its probably getting hot for some reason check the jetting, airleaks, water pump, antifreeze leaks etc.... Also could be detonating, what size domes are in the head?? is he just running pump fuel, he may need race fuel something to start with maybe
  12. to canada? and your positive its the lt230s not the lt230e?
  13. sorry for posting this on this site but its the only site i know of for these types of questions, or if anyone can point me to a 4stroke site where somebody may know that would be great as well Anyways my buddy picked up a lt230s in parts and asked me to build it for him, the project is going slow but now i am at the wiring, off the stator its similar to a banshee since its a kickstart bike. there are 2 plugs that i hooked up, there is no way they go to the other plug, different connectors. then there are 2 mysterious wirings coming off it as well. the bike got painted with the wiring on by the moron before me, so i scraped the paint off and one wire is blakc and the other is orange it appears. on a banshee orange goes from the cdi to the coil, but this orange wire i thought was like the yellow light wire coming off the stator of a banshee and the black i thought would be the same as a banshee and just ground it out. thats not the case though if you ground the black there is no spark on the bike. Everything else seems hooked up correctly, its a new plug so its not a plug issue. \just wondering if somebody could help me out and let me know where these 2 wires belong, then i can go from there and try and figure out if its good or something else is up. i am kinda suspecting a bad coil because i have tryed these wires in several spots now and nothing. thanks guys
  14. will it not rev at all???? like not even 500rpm???? If thats the case check all the TORS junk, you may have put in the eliminator kit on your carbs but forgot to unplug a part of the system, that happened to me once and same symptoms, check the black box attached to your frame above your left cylinder, if its plugged in, unplug it and throw the box in the garbage to save the problem next time Also a plug for it runs to your brake lever as well I beleive, mine has been gone for so long i forget now, but unplug that one as well........ or maybe that was the brake light lol just try and see what happens
  15. Hey I know its the wrong forum, had this topic on the jetting forum for a day, no replies, i know this section is more popular so i tryed in here Anyways I got a set of pod filters for my banshee but dont know where to start for a main jet. I got fmf pipes, shaved head, wolf cdi, mild port, stock carbs, everything else stock, at sea level I was thinking like a 320-340ish or so but I wanted to ask before I go wasting money on jets, tight on money these days lol. Thanks
  16. Hey I got some clamp on filters for my banshee wondering what size jet I should go up to? The mods are, fmf pipes, mild port, stock carbs, shaved head, wolf cdi At sea level, and ya would like to ditch the airbox and put clamp on filters on So what size main should i go up to Thanks
  17. I just picked up a banshee in pieces Anyways doing the front brakes, I put new pads on When i was bleeding them everything was fine But now when you pull the lever first there is very little grab, like you can pull it into the handlebars and the tires wont lock up but if you keep pulling it it grabs better and better, if you pump it like 3 times they lock up no problem I bled these sluts about 40 times and its still the same But Ive been bleeding one side, then pump them more and bleed the other Also noticed a small fluid leak near the rezzy on your bars but cant figure where its coming from, the bolts are tight on all the lines Any suggestions why they wont stay strong? Bleed them at the same time? Bleed them more? or is it something to do with the small leak Thanks
  18. hey thanks for the help guys got her wired up lastnight and sparking good
  19. ahhh thankyou so no regulator for me then lol who needs lights and I pretty much got the wiring or do have it lol? gotta install the tether though, need something to shut her off
  20. Do you need your voltage regulator to run or is it just for the lights? And whats the bare minimum wiring you need to run? I seen a wiring diagram and it looks like you ground the black wire from the stator, plug the connector from the stator to the cdi Then ground the main switch wire forget the color, ground the kill switch wire or do you leave it ungrounded? and run the orange wire to your coil and ground the other side of the coil this right? Somebody let me know Thanks
  21. Looking for a rear brake caliper cheap as possible please Somebody who will ship to Canada or lives in Canada Will pay with paypal or whatever you choose Thanks Ryan
  22. maybe a slide is stuck open that would make your throttle easier to push
  23. home port? looks pretty rough
  24. what kinda trade you looking for i have cylinders 0.08 over though +pistons, mild port, ligtened flywheel, stock stator, cdi, all the wires and shit you need, adjustable timing plate what kinda cash are you lookin for on top of that? do the pistons come with this deal?
  25. i thought about a tach a while ago but it seems the only one that works is a really espensive computerized shit what woudl happen if you stole one from an rz or something? that might work but you would need a battery probably
