ToomeySheeLE
Everything posted by ToomeySheeLE
  1. Ah.. Well I was running it with this jetting in the summer/fall I knew it was a bit rich then, but wasnt having near the issue with it that I am now.. If I cant figure anything simple out in the next few days I'll take it home on the weekend and put the tools to her..
  2. Southern Ontario! Hey Mason07, do you ever come back to the Lindsay, Ont area? Im going to college and living in Lindsay right now
  3. Recently brought my banshee up to the place I'm staying at school, and looking to get it out on a frozen lake.. Problem is, I dont have many tools up here and its not wanting to run too smooth.. Its a ported 4mm, Cpi's, 35pwks I have it jetted fairly rich, 160mains 55 pilots, cel needle one spot down from the center.. I can get is started with full choke, and need to play around between throttle and choke to get it to keep running when its cold.. when its finally warmed up enough to ride, I give it a shot of gas and it often falls on its face and dies.. then can take a shit load of kicks to bring to a run again....which i find weird.. I think my airscrews are about 3 turns out, could it be as simple as turning them in to get this thing on its feet again? If its as simple as that I feel stupid posting this, but Im sitting at college bored out of my mind.. nothing better to do.. Thanks for any help.. Brad
  4. Bump, still have these cases. Just like new, comes with new clutch acuator bearing for the top case. $275 shipped
  5. Stock port and stock stroke? 34's would definitly be too big ... I agree with the last post.. 28's or just stock..
  6. I'd like to throw another vote out there for Flotek.... Excellent work and turn around time... I think my 4mm port is stronger than most other 4mm jobs, and its very fair prices!
  7. Stock,std bore pistons 6hrs run time, mint condition, $75 shipped Noss 21 and 20cc domes cut for a 4mm crank. both sets just like new, neither was used for a whole season. what are these worth? $60 shipped each set? Perfer money order if interested.. Can get pics next weekend.. thanks Brad
  8. Thanks guys, I will rig it up in the stock location as you've done.. If you want to buy one I'd HIGHLY recommend getting it from Denny @ www.flotekperformance.com I truely believe they offer a much stronger spark and better burn, not sure how much of that can be felt in the seat of the pants though..
  9. Hey guys Just wondering if theres a company that makes a bracket to mount the nology coil on the banshee? I read somewhere that its best to have it placed a couple feet away if possible from the head(not sure why this is) Currently I have mine taped on my frame with electrical tape.. its a real hack job, but its making due at the moment.. I might n*gger rig something up out of aluminum if I cant find a better solution... thanks for any help Brad
  10. Thanks Adam... I'll get some pics up this weekend.
  11. As topic says.. In need of money and I'll throw these up, but defintly wont give them away.. Absoltly mint 05 cases with a fresh powdercoat of gloss black.. $325 money order only Email me at [email protected] for pics.. Hope to get some this weekend..
  12. I modded mine and they're holding up great.. Just drilled 2 small holes in each one and put a small bolt through, then locking nut on the other side.. I would recommend using locktite, and make the holes big enough that you can use the largest diameter bolt possible without wrecking it all together.. I tried smalled ones and they accually would break the ends off from all the vibration... Good luck
  13. Wow.. no one needs a mint crank? $115 shipped.. guess I'll keep it if i cant get this much...
  14. Bump Still for sale
  15. pics have been sent to the two emails i recieved.. let me know guys.. thanks Brad
  16. No its not trued and welded. came out of my bike with less than 30hrs on it.. you could have it welded if you wanted.
  17. I can do paypal, however i would rather do money order and anyone that can do money order would be get priority.. I will send you both some pics tonight.. Thanks
  18. Ok i have a mint set of OEM pistons.. 6 hours of run time. $60 shipped Tires have at least 75% tread on them, no plugs. 135$ shipped. Pm me if you want pics.. im away at school right now, but can get some on the weekend. thanks Brad
  19. Hey guys, I have had this sitting around too long and it would be great to get it out of my room and to someone who could use it.. Its a MINT crank out of my 2003 banshee, I took it out in 04 and I would say it has less than 30 hours on it.. All packaged up and ready to rock.. Bearings spin like new and there is no excess play anywhere. $130 shipped.. Brad
  20. My ports weren't lined up and the blowby is the oil thats been running into the ring area of the piston. Corrective action has been taken. Thanks for all the input
  21. Assuming they weren't honed(Im honestly not 100% sure) would I be able to hone them now and put a new set of rings in and have them seat correctly? I'm running blue marble 32:1, been using this oil for a few years on another motor and never had this before..
  22. Broke it Correctly... 3 heat cycles then took it easy for a tank.. Always let it warm up good before hammering on it..
