djackbanshee
Everything posted by djackbanshee
  1. Thumb i race mx and you get too tired with a twist
  2. That would of been ok if it was written blaster on it ::
  3. My opinion would be carbs are too big, lack of bottom end go with 30 or 33 pwk carbs
  4. Tell your friends LOL I Think anonymous members will also count !!
  5. So cool seems to work out fine for most !!!!!!!!!!!!!!!!!!!!!!!!!
  6. heres mine they are longtravel 17 inch shoks This is my swingarm
  7. This is the Final Date , Be there Titles says it all be there Thanks !!!! Trying to go after that record . 500 is alot but we can make it . It's important, everyone who reads this pleasee be online at that time we are going after the most users online in the same time record dating from 2004
  8. Everybody try to be online On February 3 next weekend on saturday ,say 6:00 eastern standard time Is it fine with everyone? If this could be put in Important topics on top Pinned it would be fine
  9. I think it would be cool to beat that record from 2004 Let's give time and date where everybody would try to connect in the same time and beat the record from 2004.
  10. Heres mine
  11. Here's mine execpt the rear fenders are not race cut !
  12. Ive already put a blaster engine in a yz 80 frame and the biggest problem is it was unbalanced the motor dtock out to much once the chain was enligned and it at low speed you would always feel it pulled to one side. But it would be possible to fit a banshee engine in a yz 250 frame . If your buddy kinda rides in dunes or hillclimb. The balance does not matter that much. I've already seen dirt bike with snowmobile engines which are heavier than banshee engine, As pipes you could use rz 350 pipes.
  13. You are better with this kinda setup !!
  14. What's different between the rz and banshee forks ? why is it better ?
  15. 13$ down the drain.......... leave the stock tube there just some guy that came out with this idea.. i d'ont think they do anything, there just there to get rid of the crossover tube.
  16. Why Not?
  17. Thanks ! big red at least ive got the rz tranny feel free to help me cutting my own and help me with the springs.. Any clues would be appreciated . I kinda have no choice to make my own
  18. Anyone knows where to cut a dunable override? I would like to try my own since no one makes these in canada and shipping one and back to the states would be a crazy price.....
  19. Streamline
  20. I will be doing the yfz rear shock conversion. I will also do the front a arm. I will keep the banshee style frame with the yfz geometrie . The frame will be narrowed in the front to be the same measurements as the yfz, so Yfz a-arms will be a direct bolt on .For the rear i will use the Yfz shock and linkage , i will cut the old shock mount off and just keep the pipe as a motor support and make a support alot higher which will not fit anymore with the stock airbox The bottom has to be modified also to bolt the yfz linkage . I will not use the yfz swingarm , which i think does not fit at all in any way on the banshee. I will make my own roundhousing swigarm banshee style wich mounts to the yfz linkage . I have started collecting yfz parts for this project and i will keep you's posted while i build this.
  21. 250 r geometry chassis all the way paul turner mid pipes Mx porting or powervlave cylinders 2 into 1 carb setup
