no, sorry Stan I dont. yes its one of those earless bastards. the picture shows pretty well what goes on. that rubber seal on the end rests against the end cap of your shock, so it faces towards your rear tires if you will. you can see the groove atop the AL portion of the head, thats where the circlip resides. now you just go in that portion of the shock body and cut into the SH directly behind the clip. cut as big a portion as you like, but you have to get a pick or two in there to get it out. once it has started coming out you get a firm grip on the clip with some needle nose and twist the SH, virtually unthreading the clip from its groove.
Cutting the groove, I used a small air powered right angle die grinder. Im sure a wizard or a dremel toool would be fine. use a small bit, what ever you are comfortable with. Theres a pretty big area (realtively) to play with, so get a bit you can control so it wont cut into your shock body.
