DIRTMAN350
Everything posted by DIRTMAN350
  1. thanks for the compliments. like samc said they are the kenda klaws. You can run them either direction. they seem to hookup pretty good.
  2. No takers?????? :sad: :sad: :sad: :sad:
  3. Contact me at 515-965-0766 after 4pm. Also have rear sand tires mounted on rims and front single rib tires. http://s47.photobucket.com/albums/f187/Dirtman350/
  4. Banshee for sale. See Pics attached. Let me know if interested. [email protected]. For sale local only or can pick it up.
  5. I used an air saw like the one above. Have to go slow or you can make a bad cut in your plastic.
  6. You may not see any imperfections in the o-ring but it might be flattened on one side. Make sure you clutch cover does not have and burrs in it when you assemble or it will cut oring. I usually put a light bead of silicone on oring before assemble just to ensure a good seal. Use sparingly.
  7. You'll have to remove the head and see hwat the numbers scribed into the domes is. Otherwise you can talk with the guy you bought it from and see if he remembers. Also make sure if you replace the domes check your elevation and make sure you get the right ones.
  8. Same here torque em down in the head and then snug em up with pliers. Don't get to carried away tighting them up.
  9. No Prob man. Whichever tire u decide on I'm sure you'll be happy.
  10. Klotz Supertechniplate 32:1 ratio. Been running good and strong for over 2 yrs now.
  11. I use Klotz Spertechniplate. Love the smell and no problems for over 2 yrs now. Motor looks just as clean as it did from the factory in 1998.
  12. You say you got your parts from jeff right. just give him a call and he'll take care of you.
  13. Ihave the Klaws on mine and think that they hook up pretty good. My bike is mostly stock.
  14. As a GM tech i can tell ya that with a improperly tuned dmax with a chip does some serious damage. I have seen it first hand. Make sure at least put a egt gauge in to mointor your exhaust temps. If you still have factory warranty you might lose it if the dealer finds out you had a power up device on it. Personally I'm strongly against power up devices but to each his own. I work on dmax's all day long and they are strong engine. Had a customer install a chip on a lly motor and burnt down two holes in the block. melted the tops of both pistons and scored the the block. That little repair cost him his job with the company and he had to pay about 15,000 for a new motor plus labor. If you know how to use the chip wisely you might be safe.
  15. They don't have a chance in hell tanking my guns and ammo. If they are man enough to take them i guess i will be going to jail for murder because i will use every shell i got. Piss on the politicians
  16. Here you can check out a pic of mine on my bike. They are Tusk nerfs from rmatv. fit is good and havenot had any problems with them.
  17. I use dvd decrypter, dvd shrink, and fix vts with nero buring engine and i can burn almost any disc wether it is encrypted or not.
  18. either plug will work fine. I would stick with one and stay with it.
  19. I'll have to order a couple myself. Nice find.
  20. Hey Jeff, How so i go about ordering up a shirt. I haven't been on here much and did not know you had your website up and running. Should i just drop you a line to order a shirt? If not let me know the proper way. Oh by the way I like the top shirt. But both will get the job done!!!!
  21. This how my clutch cover came out with wet sanding and polishing. The pic might be a little hard to read.
  22. post up some pics and let us know how it turned out.
  23. If ya got some extra $ laying around hit up noss and get yourself a noss head. He can hook ya up. Dave is a awesome guy with nothing but good products and service.
  24. I highly recomend oem but when in a pinch you gotta do what ya gotta do. whenever your talking about seperating coolant from crankcase oil I use oem gaskets
