PUSH THE THROTTLE
Everything posted by PUSH THE THROTTLE
  1. LMAO, who had that simpsons avatar where Marge is blowing flanders?
  2. No kiddin' how bad did you F up?
  3. Sorry Sredish I have too.
  4. Make sure you get shiney ones that's all that matters
  5. I cannot believe you'd leave your jetting stock on a bike with no airbox lid and pipes. I think the old owner was a jackass.
  6. Good deal, I wish we'd hear more of these stories
  7. I got mine from dennis kirk as a kit with the lube it wasn't very much maybe under $10? I'm sure rocky mountain has them too.
  8. Make sure you get vids, I'd like to see what happens.
  9. Nice review Sredish, I'll have to check that out. I haven't heard about it before.
  10. Maybe your post would be better suited in the MX forum?
  11. Depends on your target market.
  12. I don't know anything about power pistons but if you put your shaved head back on and the compression is higher run race gas and I would think you should be fine. Maybe somebody knows more about those pistons. See what the compression is with it on. Also do you have a welded crank? you might want to think about having it done if you get your compression really high.
  13. From Noss's web site it appears that at sea level you'd need race gas since compression would be near 169, at 1300' you'd be ok on premium pump gas. Noss's chart tends to be conservative. But since your machine isn't new you might not have that high of compression. You need to check it and if you're near 160psi run race gas.
  14. I have one and it works. Not sure of a better way.
  15. Why don't you just test that theory?
  16. I don't understand what do you mean he took the domes out? you'd have to replace them with another set of domes if you took them out. Does it have the 20's in it right now? What's your elevation? Any timing advance? Have you checked your compression? If your compression is over 160 you need race gas.
  17. I got mine from Dennis Kirk a while back I see they are expecting 16 tooth mooses in soon. I think I have a JT that I got from them but it doesn't show on the website.
