FoxBansheeRacing
Everything posted by FoxBansheeRacing
  1. Yes, everything is included
  2. Ok, I think I have everything figured out except what what hole is? Can someone with Keihin pwk's check out their carbs and see what this hole is?
  3. That cant be the hole for the choke because I know where that one is. It is right below the smaller hole, but on the surface you cant see in the pic. I do need to buy new chokes for them. I would just email the guy and ask him what it is but his email doesnt work. So far I have ruled out the choke and air/fuel mixture screw, so what else could it be? Blueduece- so your saying I am going to need to get some kind of a connection that will T of my fuel line?
  4. Thanks for the help duece, but those pics are hard to make out. While I was looking the carbs over I found a threaded hole that goes into the top of the carb. What could this be? I took a pic and put arrows on it cuz its kinda dark and hard to make out, the red arrow is the mystery hole, and the 2 green ones are the gas fittings, which I'm still not sure how to set up.
  5. Ok, I bought these carbs from a guy off ebay and they didnt come with any gas lines, so I'm not sure what goes where. Could you give me an idea of how it goes together, like which line connects the 2 carbs together? Here is a pic.
  6. I need some help jetting my new 32mm carbs. Check my sig for all my mods. I am running 500-1000 ft above sea level in 40 degree weather. Where should I start? I currently have a toomey 2 into 1 filter, but the boots are too small for the carb, can I get different boots or am I going to have to get clamp ons?
  7. Here is a link to mine on ebay. It is a steal considering other guys are wanting over $300 just for the intakes. Carb setup
  8. I would think getting the big black culvert tubes would be cheaper than buying a bunch of plastic drums. I think they call those kinds of fields hyperball, its pretty cool cuz you can crawl through the bigger tubes. You should also be able to find those pretty easily.
  9. I didnt want to start a new post and have a question. I need help jetting my new 32mm keihin's. Check my sig for mods. The air filter is a toomey 2 into 1. What should I start with?
  10. I'm just going to put hose clamps on there and see what that does. If I was to put a regular o-ring on the pipe, would it melt it?
  11. Ok, great. Will the stock boost bottle be ok or is it a good idea to get an aftermarket one?
  12. Yes, those. The stock ones are too big for my gnarlies. I never thought about hose clamps though. I have ran into a problem with mix and matching pipes and silencers. I have to cut like an inch or so out of my stinger for the pipe to fit on there right. I will check ebay.
  13. Yamaha blue is the best, but stress mark blue sucks.
  14. I will be racing mine this summer. Heres a pic.
  15. What is the correct name for the fitting that connects the header pipes and stingers? Where can I get one of these to fit FMF pipes?
  16. First off, I have 29mm carbs that have been bored to 32mm. When or if I get new intakes do I need to get 29mm or 32mm's? The size is also in reference to the size of the opening of the end of the carb going into the intakes correct? Will my stock intakes fit on these carbs or will I have to get aftermarket ones? Thanks.
  17. Stock wont work with 32's I thought.....
  18. Because you need it, and all I have is the stocker. I've heard blocking off the holes in the intakes make it run like crap.
  19. I need a set of intakes for 32mm carbs. I will also need a boost bottle. Reply or PM.
  20. Here is a link to the pics. The reserve on there is like $260, I will sell them to the first person with $150 plus shipping. Link
  21. I have a set of black T-5's for sale if your interested.
  22. Yep, those are old school fmf's. Back then they made two different kinds of them, "woods" and "top end". Hearing your discription it sounds like you have the top end ones and the other bend type were the woods kind.
  23. Thanks for all the help guys. I won the auction for $122.
  24. Sorry for the double thread.
  25. I found a set up 29mm keihin carbs on ebay bored to 32mm. They are selling for a pretty good deal, they are just missing the chokes. Should I get them? How hard will it be to find the right size intakes for them? Please help quick, the auction only has about an hour left. Should I wait and try and find some mikuni flatslides?
