screamingtwin
Contact Methods
  • Website URL
    http://
  • ICQ
    Long Island, New York
    2001 Banshee FMF pipes and silencers
screamingtwin's Achievements
  1. Does and body know how much to torque down the head bolts to? Any info will be greatly appreciated.
  2. I am having the passion motor put on. All I do is motocross. I was wondering if anybody with the passion motor has put on the 2 into 1 carb setup? If so does it add more low end and smooth out the powerband even more. And what size do you recommend the 33mm or the 35mm?
  3. Paul Turner Mid pipes will give you the power your looking for. (trust me)!!!!!!!!!!!!!!
  4. The gytr a-arm skid plates won't fit your extended a-arms. The best tires to get are kenda klaws all around. 18/10.5/8(back) 20/6/10(front)
  5. What kind of riding do you do?
  6. KENDA KLAWS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GODS GIFT TO THE WORLD
  7. Can some one tell me how I can get a passion motor???????? I need to to to that jim guy. What is his user name?
  8. I race motocross with my banshee and I was wondering if the dyno port 2 into 1 pipes are good motocross pipes. I have FMF fatties on now. I need something with some more low end grunt to pull out of the corners. Four strokes pull so hard out of the corners and it's getting hard to keep up. So is the 2 into 1 system good for motocross? Im looking for low end grunt and a smoother powerband?????
  9. How much do Duncan Racing pipes cost?????
  10. Does anybody ride at island motocross in new york?????
  11. I wondering if the trinity 2 into 1 carb is any good? All I do is motocross. Does it add any low end power. Any problems with it?
  12. I was there when his axle snapped. Are you the guy with the blue banshee?????
  13. It only squirsts out once in awhile? Could the master cylinder be bad?If so how much does it cost?
  14. If you take the hose off the master cylinder should the brake fluid pour out?
  15. I just put on brand new stainless steel brake lines. And I don't know how to make them work again. I tried letting them just sit there so they would gravity feed but it didn't work. I can't seem to get any fluid in the lines? HELP!!!!!!!!!!!
