23champ
Everything posted by 23champ
  1. Ouch..thats cuttin it kinda close. Hope I have my rig goin by then. Buzz, You need to post this stuff on your web site!
  2. 1. did you make sure you installed the pressure plater correctly? If you didnt , there wont be any clutch pull on the lever. 2. Did you line up the arrows? The clutch arm ( where the cable hooks to the arm on the cases) is shaped like an arrow on the end. That should line up with the arrow on your cases....kinda by where your VIN numbers are on your cases. 3. Are all the parts to the clutch installed correctly? There ia a little ball that goes inside the mainshaft. it sits between the pushrod and the pancake bearing (if you have a pancake bearing installed) 4. You should have enough freeplay in your lever that you can stick a nickle between the clutch perch and lever.
  3. 23champ
    Drag Motor
    Get the biggest you can afford!!!
  4. 23champ
    Drag Motor
    If I were you, I'd go with the cub. It will run better and prolly be cheaper ( if you use stock crank).
  5. www.bfd-atv-drag-racen.com
  6. 23champ
    Carbs
    I have a set of PWK 35's and a boss intake..both are like new. $300+shipping. PM me if your interested
  7. bitches
  8. looks pretty fast!!
  9. ...(period)
  10. how long has it been in there?
  11. replied to PM's
  12. You like the blue and white color scheme huh?
  13. hmm.....good luck!
  14. I have a pair of 28mm keihin PWK's. these carbs were only used for about 3 months. like new! $175 o.b.o. +shipping send pm if interested
  15. I've never used it before, but I always heard that it worked good if you follow the instructions.
  16. I've heard bad things about vitos cranks..If I recall, I think it was bkabina on here that had one break and destroy his motor.....I have a hot rods crank (wiseco) and the welds have broke on it. 6 of one, half a dozen of the other......................
  17. They been out for quite awhile now. They kinda sound like a gimic to me, but who knows?
  18. I didnt know Toomey made throttle cables
  19. 23champ
    ds650
    looks like some pretty mean ass 650's you guys got!
  20. looks like it would be a good time...good luck selling!
