94BansheeRider
Everything posted by 94BansheeRider
  1. When my stock CDI finally died, I put on a Dyna FS and couldn't be happier. I has four pre-programmed curves in it that is adjusted by the flick of a couple of switches.
  2. I run Maxima Super M at 32:1
  3. Another note: Check the rubber sealing compound that holds the electonics in the CDI box (the side where the wires come out) for signs of cracking and disfigurement. This is a sign the box is giving out. Are you running resistive spark plugs or have changed the plug boots to aftermarket?
  4. How old is your bike and does it have the original ignition box? I had the same problem on my 94. Finally one day even a pull start would not turn it over, and I had just ridden it hard for an hour or so. Turned out that the stock ignition box was gradually "frying", then died altogether. If you can borrow another CDI from someone, it may be worth a shot. Just a thought...
  5. Thanks for the info guys. That's what I thought, just wanted other opinions
  6. I have a couple of pints of Klotz racing oil and was wondering what the correct process is to switch from Maxxim 927 to the Klotz without any problems with the different brand/type. Should I burn up as much of the other fuel as I can then drain the carbs to do the switch? Any help would be appreciated, thanks.
  7. I changed my 94 blueish purple to 97 black with no problem. You might try to find an earlier year with the color you want. I think they changed the harness connectors in 00 or 01.
  8. Does it still have the stock CDI? Mine finally gave out after 9 years, about an hour of riding one day. Shut off the bike, then went back to start it and no go. Wouldn't even pull start. The CDI had fried. Sound like your problem could be the CDI or maybe the plug CAPS need replacing. Good Luck.
  9. sredish, I am glad that you survived such a nasty wreck like that. I wish you a speedy recovery. You'll be back and riding before you know it. Best regards, Mark
  10. I saw the vid today, and I gotta say that I never want to see that again. It made me so angry the these chicken shit terrorists have to resort to disgusting things like this to get there point accross. I say if we find them, we should string them up and feed them their own testicles. What a sick thing to do.
  11. Anyone ever listen to Opeth? Just curious if anyone else is a fan.
  12. For all you Metallica haters... http://www.metallicasucks.com
  13. Here you go... http://www.performanceunlimited.com/cobrav...valvestems.html
  14. LOL Funny!! Cliff 'Em All kicks ass. That bass solo will go down in history
  15. If you want to check out a REAL metal show, go to the Headbangers Ball Show. Went last week in OKC, and it was cool. Damageplan had to cancel, but Hatebreed, Drowning Pool, and Unearth was worth the 20 bucks for the show. I have been watching Headbangers Ball every Saturday latley, and guess what??? NO METALLICA being played on there. That should say something...
  16. Metallica sucks donkey dick nowadays. They went downhill after Master of Puppets.
  17. oldasdirtrider, I know for a fact you are an expert at what you do. I want your job...
  18. Too short of a throttle cable? Slide in backwards? Just a thought...
  19. Naked is cool. I blasted mine last year, now I'm thinking about polishing them
  20. Had the same problem with the rubber bumpers falling out. Glued in.
  21. I have a Dyna. I love it. It was a toss up with MSD, decided to go with Dyna.
  22. Oh yea, I use Bellray Gearsaver 80W. I had a problem with mine slipping using 10w30. Need oil with friction enhancer.
  23. He means roughing up the surface of the steel plates. I bead blast mine when I do a clutch changeout. Over time they get smooth. By roughing them up, it gives the fiber plates more grip.
  24. On one of the early C-17 sims we did, the visual tech flew me out over the Atlantic to where there was a small life raft. Inside the life raft was George Bush, Sr.
