Oilsmoke
Everything posted by Oilsmoke
  1. You have to have a witness See you do it before you are giulty. Than you will know who Narc'ed you off. But a pussy don't have the balls to do it.
  2. Air Box?
  3. Where are the best places to buy a Good crank from?
  4. The cirleclip spin freely inside the shock end, that is little reason of this problem. I NEED a better stronger small pointed tool. But no matter like i siad i clean them out and replaced the grease with new and installed them on the shee.
  5. I bent the Shit out of my dental pick. there still in there with fresh grease. I live with it untill I feel like trying agian.
  6. Meat I just tried to remove mine, Man that clip is a BITCH i cleaned and regrease them and Walked way. How the (*!@^#(&%(^*(!(#^ did you get them out?
  7. So how do you use a Long rod, Stock stroke crank assembly? With or without the 795 piston, if so do you need a plate or custom cut dome so to you don't change the port timming? I think this the Crank that Ducman Question started from. I wonder about this myself because i trying to plan a High rev shee to go with my Shearer pipe that can handle the extra RPM's that the pipe will let the motor make. It's like 11,000+ @peakHP.
  8. SO how the shee run?
  9. Reas11 I thought you was going to roostfest?
  10. Can the rotating crank Mass be balanced as a whole unit? Pistons, rods, crank, flywheel. For a superior Balanced & blueprinted Engine.
  11. Dunedemon what Gearing are you using? Tell about your porting & carb combo too.
  12. Big Blue How Hard does it pull up steep hills and do you feel like you need more carb with them?
  13. CPi's are great fun at the Dunes. My son's runs them . I just bought a set of Shearer and will test them agiasnt them Cpi's soon.
  14. OK so how about side tolerances, what are they, & can one check with feeler gauge .
  15. Is there any way to tell if a cranks been welded, while it's still in the case? And what are the tolerances for the rod journals side clearance?
  16. I would 2nd that. Call Jim at Passion Racing Engines Tulsa, Oklahoma 918-232-3950 or 918-272-5665
  17. Cool, I'am sure there is Only One Shearer Pipe company. He learned is trade from Kenny Roberts That Man knew how to Haulass.
  18. Will It Could be Matt, I thought i read somewhere his name was Jim. Don't shoot me I am only the Piano player.
  19. Well I joined the Club, I won my Bid on a New set of Jim Shearer Drag pipes. SO i am Stoked . Damm I feel like a Kid agian. Muhehehehehe. Jim Passion Racing I am tossing around the True & welded Crank, Can they be balanced & blueprinted with the flywheel that will be used? and would that 12 port make horsepower at 10,000 rpm If that pipe will let that motor wind up that much? I just thinking out loud.
  20. My Son's SHee ( test bed) we installed a set of 28mm Mukuni Flatslide that we got off Ebay New for 189. plus shipping and Man did it wake them CPI's up. Big Time Difference. But it was Not enough for Him. Hence the (test bed) Nick. He as Now installed 34mm flatslide Mukuni Both where the TM model. He have not ran'em yet But plan to next weekend to See much over carbed( my thinking) we are. His Plans are for Pure Hill Shooter only type machine. His shee is Ported & Pohished, Billet intake without Cross over, Reed's are TDR's with Ported stock cage without Vertical center brace, Noss Head 18cc, Cpi's inframes, adv'ed timing plate Lighten flywheel. I can say this It was dam Fast with only the 28 compared to the 26mm stock round slides.
  21. I have a dune only machine in the works now and I hashed over the problem of picking a pipe. My son machine & his best friend both have Inframe Cpi's and they flat out fly. So I diceide on Shearer Custom So I can Beat them. But i am not sure I can. But after all I ported them both, I just have to see whos Got the best setup. this is where the part combonations come into Play a major role. Reas11 You tested them yet?
  22. Bikebandit,com has them for 3.95 and 4.61 plus shipping. so i am guessin about 11 dollars Cotton eyed joe that sounds like a great idea for the top clamp. I think my rings are still good in the upper clamp.
  23. I need the two seals on the steering stem, Is there any aftermarket places to buy them.
  24. you could call Shorty racing? he sell CPI's & cranks I think. Webpage I never bought from him but I did call on a set of out of frame drags.
  25. I agree banshee04le, NOS port and a place to go.
