bansheefreak
Everything posted by bansheefreak
  1. its not that hard.. just pull out the old stem like wallace said and put a new one in backwards so its in the wheel this will plug the hole like wallace said.. then drill new hole add another stem and walla..
  2. im selling a like new hinson basket,innerhub,pressure plate,8disc clutch,springs and bolts.. package deall alll hinson..
  3. is the swinger round house??pics??? i might have a 4mmstroker crank we can work a trade if he has some money
  4. who said this???? when you buy a cub you get a 392 which is stock stroke or you get 421 which i designed for a 4mil crank..
  5. you can add or take away weights from the lockup to regulate how hard the clutch engages...
  6. cheetahs are sold.. thanx tim..
  7. yeah that :shrug:
  8. i run a passion dunable.. shifts like butta!!! but always hear good things bout redline and wcr.. i think rudy kurtz does kickass override too...
  9. 91banshee has one for sale brand new.. you might pm him..
  10. 34 will work . this motor had 35's on it.. prolly would be even better with 39's but 34 and 35's will work fine.. intakes are for 34/35.. come with reeds.. pipes i would suggest some shearers or cpis..
  11. almost had them sold but dudes girlie said no so bump it up thanx..
  12. hmmm.. hey kotin i got some stockers i'll trade ya..
  13. yes i noticed it does reqiure the longer studs. i wil have to get them out of cases but the longer ones will come with the deal... if someone needs the 4mm stroker crank i can add that too.. for a determined fee..
  14. nikasil look good.. no chips or anything.. could prolly use a hone if you can hone nikasil.. just look at the pics.. you can see
  15. there trinity.. not sure on how much porting if any.. just a banshee im parting out..
  16. well my point was 20 over/stock/ 100over your compression should be over 110 to 120lbs anyways.. and each cyl should be close to same readings... so basically when your doing a compression check the info on the bore is not needed.. but i may be wrong.. correct me if i am.. cus all the 20over tells me is there is room to grow.. if compresion is low..
  17. selling 421 cheetah pv.. comes with trinity head with 19cc domes,upp intakes,reeds... cyls look good but needs a piston kit and oring kit for the head since i had it apart.. $1200 shipped.. enjoy the pics and last pic is a lil comparison to some stockers..
  18. hold throttle wide open and kick it till the needle stops moving.. main thing you wanna see is both cyls close to same psi .. the bored 20 over dont mean shit..
  19. i just happen to have a set of 421 cheetah pv for sale in anyone is interest pm me.. got pics coming soon soon..
  20. i have a duner 12 port ... not bad for lil 3 fiddy.. very happy with results.. it runs!!! :shrug: "im not your daddy but i'll spank you like your daddy"
  21. if i had a rz trans i would run it.. pretty sure it has lil higher gearing and diff spacing between gears.... since it came from a rd bike..
