JKJK
    3
Everything posted by JKJK
  1. a good friend of mine has a 2003 blk+red,k+n filter,procircuit pipes.about 5 tanks of fuel nun through it. absolutely mint adult owned.title,cert of origin,5000. firm.located in ma.cape cod.if interested pm me for his phone#
  2. yes it makes a huge difference! i just installed+ran mine and was like HOLY SHIT.now the power is right now,instantly on the pipe.i would highly recomend the boon toon,it's a blatently noticeable improvement in power delivery!!!
  3. JKJK
    Toomey,hush kit
    brandon,pm me with your mailing address+i'll send you a money order.thanks john
  4. JKJK
    Toomey,hush kit
    pics would be great,is it the one with the spark arrestor or wo? how about 50$ less than you paid for it new,assuming its mint.shipped to 02664 thanks for the reply.i'm mostly concerned with the noise factor.did it make a noticeable diff in sound levels on your ride?
  5. i have a similar set up at sea leavel,mine runs best with a stock pilot,320 mains,clip in the middle,1+1/2 turns on the air screw.(dyno-jet needles)
  6. JKJK
    Toomey,hush kit
    i was going to by new,figured i'd try here first.
  7. mucho thanks matt! i recieved my shirts+they look great.i would expect nothing less from ya,after seeing how your roostfest shirts turned out.you do exelent work.
  8. nice! i noticed that pic last night as i was thumbing through the new mag.
  9. the fw.is stamped out then machined on the inside to remove run out from the crank hole location not the centerline?then it is lightened if needed to remove mass from the heavy side on the exterior?1 i have no doubt in boonman's abilitys,2 have no argument with anything discussed here,3 i honestly don't no jack shit on this subject.i'm just curious+appreciate all the input.
  10. agreed,except for the material that is left in the center where the pick ups are.it would only be out of ballance by half the difference in weight of the two halfs 180 apart from where the original ballance holes were. if a flywheel was marked in the center of the lightening holes,then cut.the cut depth on each side should be different after removeing x amount of material. i would think.
  11. give them a call.i'm shure they'll make it right.i've bought alot of stuff from them+allways had exelent results+customer service.
  12. so from the factory the tooling tollerences for the flywheel wern't that tight,they figured they could ballence it from the centerline of the crank hole,cheaper than making a perfectly centered hole in the flywheel.
  13. boonman i believe the flyweel i have is a unmolested factory original,i could be wrong,the holes are the same size,shape,depth but their on the outside circumference of the vertical face.
  14. if you had two flywheels, one with material removed from the circumerference+one with material removed from the face,witch one would you have lightened???
  15. very interesting question,i was wondering the same thing.if the flywheel is netural ballanced to itself+the mass of it is consistant+equal all around then removeing equal material or mass from the circumferece should make no diff. why i was pondering this theory was because i took my flywheel off to send it to ya+noticed it was drilled out around the circumference.at least 6 ,1/4 plunges.so i dove into banshee#2 +found that the flywheel on that one .it's drilled out on the vertical surface or the face.so thats the one that will get shaved.
  16. i just picked up some new stuff to try+i was impressed.it's made by wicked products.it's called lightning shine, metel polish.
  17. so yesturday i need a new dump sticker,i go to townhall to get one as i pull in i'm like hu, must be a lot of people getting stickers today.WRONG! inside it looks like a freek show! their all getting marrige licenses. some things just aint write! WTF
  18. sorry to here of the devestating news, my most sincere thoughts+prayers go out to you+your family. john
  19. sometime mid mourn,or we could leave anytime to coordinate hooking up on the highway somewhere.
  20. i went with the white with the red frame,i can send you some pics if you post or pm a email address.
  21. they just started catching them around here whithin the last two weeks.after reading about your fun,i think i'll have to blow the dust off the surf caster+give it a go.i'm a half mile from the beach so it's big fun for minor effort. fillet+release!
  22. at my local parts store(napa)i picked up some martin senour #7252lacqer brite aluminum in a 15oz spray can,or at auto zone a 5oz dupli color #88-01564 silver mc
  23. anybody else going? i'll be there representn.
  24. yo jon ,what up i met you last summer at dayton,i was the one with the blk+red shee+the black dodge with the trailer.the day jason was jumping over jimmy off the top of the hill.anyways in my possie heading to coalfest their will be a 310r,z400,400ex,and 2 banshees. john
