I think you forgot to add Rod, that your bike flat out fuckin flys.
in laymens terms ill go with that stan..........i know my stock bore after 40 brutal hours with some bolt on stuff had 135 psi in one jug and 110 in the other, but the crank was pristien....but my passion motor has closer to 60 hours on it and still has 180 psi in both jugs, i check it every few weeks for shits and grins and its holding up great, i dont know if its cause you cant ride it as hard and hang on, or its winter and the 40 hours on my stock bore was in summer at about 90 degrees and my passion motor hasnt seen 70 degrees yet, you can pound a stock bore with short gears, but geared tall with some ponies you tend to be at way less rpm's to cover as much ground....... the aftermarket crank and pistons have to be every bit as good as the stockers youd think?.......Banchetta glad to hear you stroked your bike, still running the turner pipe?, im eager to see how the dyno was, why not try pj34's, the 34's and deltas are a good combo, i think i feel a harder pull from say about 4000 rpm to 8000, than i do from 7500 on up im not sure if its cause my pipes cant pull that volume like they can on the lower side or its just the way jims motor runs, please post how your bike dynos, i have buddys with lowend ports that say they same thing about mid to top pull that you did, trinity mx ports act like that...... i think with jims motor he does a combo of things that work well together, maybe his intake with the deltas and pj's along with his 12 port do it, pipes dont seem to make that big a difference, air flow does though, not a set up for a cut stock lid.......
