wesw
Everything posted by wesw
  1. cut your chain 1 link smaller or try a 15 tooth front with a 41 rear it might work
  2. 1st off OK TERRIFIC 2nd where you drunk, high, or what when you posted this. seems just like some beyond wierd rambling of just shit.
  3. ok after looking at the ebay ad. couple ? do you run those pedals with stock blocks or v force blocks.
  4. in theory a lean needle wont hurt your motor cause you wouldnt be leaning it out so long. a lean main you will blow it up. you need to see what numbers you have on your needle, i can tell you what its like lean or rich etc also you could have a lean pilot, mid cause of the needle and your plug could look good at wot with the mains. there are many variables for the perfect plug chop
  5. my thoughts exactly
  6. go to an oral surgeon. they will knock you out, 3 hrs later you wake up and go home youwill feel like you drank a keg,but its not too bad 3 days of swollen jaw. i was so drugged up i went home and slept for 18hrs.
  7. 28 dont run dek needles they run some weird letters
  8. hmm charlie is usually pretty good on shipping stuff out. i know he has been going thru stuff, but he usually takes care of shipping.
  9. your floats are not correct. i think its 16mm or something like that from the case to the float i dont know the exact number. you will need to bend the tab soem to where the floats close a little bit earlier.
  10. if you just look at a motor its really hard to tell if they are cubs or stock unless you get down there and stare at it up close. if youre going all sleeper, it not hard to notice what ever when you blow past them. those cubs are running freakers. out of the box.
  11. i cut like 3 coils out of mine works way better
  12. if i remember right you had some funky needle, cause d34 got it to run after buying them off you. it makes all the difference with my ceg needles it ran like crap at first, started tuning and testing needles out. got it more smoother and runs like a top now its all good now, you have your setup, i have mine. also you can get most needles from sudco.com
  13. wesw
    Haullers
    i got my 21 from there maybe the dont now who knows
  14. just wondering have you tried a 60 pilot, dek 5th clip and like a 145 main i dont see how your bike wouldnt like the setup that mine does being that same builder. but i dont know.
  15. he must have changed his pilots if they are stock carbs to be really rich down low
  16. 300 -320 for coffeyville 4th clip IMO
  17. you should have to pay for any thing 1.6. your a customer of one set of pipes. ray or who ever should cover the cost. wow what a cluster of freak if you ask me.
  18. all i have to say is THAT IS THE HACKEST PORT JOB IVE SEEN. wow looks awful to me but shit it might run who knows
  19. nice pink meat curtains yummy
  20. 100 LL 927 40:1 is what ration im running maybe your bike likes that jetting. do what makes it run the best
  21. 700 bucks damnit people always get the deal i cant get shit. best of luck there adam with that buy.
  22. 16-39 is pretty high but it will pull it. it depends how you race. i usually cant go from 1st to 2nd gear speed shifting so i run a 15-41 gearing now and can start in sec. 16-39 you can wind out the gears but if you hit 6th gear you better be ready its like 75mph + too fast for me . IMO in sand it depends on what tire you run stock works good for sand around here.
  23. dgn you are leaning out the low end. im running pods also dont know if that matters with your setup. jim motors like fuel in the mid and low end. im kinda confused on why your bike wont idle, and to get it to idle you lean it out. when im pourign fuel into it. if you can find a dyno with a sniffer around you shoudl put it on it and see how the o2 readings come out on it.
  24. email [email protected] tell him youhear on hq.com that he sells savers. i could get a 16 sprocket on with his saver but i did sand it a bit for a perfect fit
  25. 60 pilot , dek 5th clip, 140 mains need to bump them up about 1 size. at 900 ft.
