rebelbanshee2
Everything posted by rebelbanshee2
  1. just a bunch of burns on my shirt from launching bottle rockets out of my hands And that oxy-acetaline is nasty stuff! My friends and i had about a 2 foot diameter garbage bag we set off once..it was F-ing loud!!! The same friends neighbor used to take HUGE bags up it with helium baloons and calculate the wind and float them over towns with a timed fuse...crazy...hes ex-marine force recon so he was alittle nutty
  2. I have a Toomey 2:1 filter setup I would like to get rid of. It has an outerware in great shape, no burns from pipes. It has only seen a summers use. PM me with an offer. I can Email pictures too. -thanks
  3. the bore size is on top of the piston, and DONT reuze the gasket!! unless you like the myriad or troubles a bad head gasket brings
  4. thanks but i dont need another set of hubs. the studs are *only* 2 bucks a pop from the dealer. I somehow won the hubs on ebay for $5.50 so i dont mind paying 16 bucks for some studs...although i wish i knew about your deal before i paid for these
  5. if you are piped i would put a 15t front on. thats probably what he did. a 15t really wakes the banshee up. pulls the gears longer with less wheelspin
  6. I just got some rear hubs, but they need studs. I need all 8 for the rear. PM me if you have any. Thanks!
  7. going up on the mains does not mean less flow. Larger mains=more gas. The only reason more gas would be needed is becasue there is more air. You would need to go up on the mains if you took the lid off too, or with pipes, porting, big bore etc....does that mean less flow too??
  8. man i was reading that, and was thinking sheesh did his mommy write this for him? it such good english....then I found is was not his and it all made sence...
  9. cobra sucks even more i think. i liked the old forum (the last one) ALOT better!
  10. I love all the irony in this post.... i found that by combining all 3 of his names you can get a rather humorous and fitting name for him...StonedGuyRider....Its so perfect!!
  11. boonman why do you do it on a surface grinder? Wouldnt using a face mill give you a good enough finish and be much faster? Or do you surface grind so it is more accurate?
  12. i almost think its fzr600 but im not sure
  13. you modify the shift star. Im sure boonman will reply to this hes the guy on here that most people have to it
  14. thats a vertical mill not a drill press!
  15. well seeing that yours is an 87 it doesnt have a brake light its just a tail light...the rest i dont know
  16. if you are jetted with 220 on stock carbs with T5s you are so F-ing lean its not even funny....if you meant 320s then you are way rich and that could explain why you are uing so much gas
  17. the EBC can be run with the stock, basket and hub since the plates are thiner than stock. kinda a trad off more surface but less heat dissapation. The hinson uses 8 normal plates, so it would be better. I would love to get the full hinson 8 plate setup with the basket with straight cut gears on it. If i have $900 to spend on a clutch that would be it right there!
  18. put a 9 tooth front sprocket on and you will go 150 easy
  19. anyone?
  20. first spline? I dont get what you mean by first spline. do you mean the splines for the wheel hub? it should slide right on from the left side to right side. if you are trying to put in on the wrong side i think maybe the brake hub splines are larger
  21. My Webpage here it is. the whole popst is pretty dumb
  22. I was bored and scanning atvconnection.com and I came across this that rather amused me....
  23. I wouldnt get just the wiseco kit with just the spacer. I would deffinatly get the porting corrected for the stroke and either use a spacer plater or cut head. if you dont port for it you wont get near the gains you should get
  24. its seems to me there is some provision in the law for when something like this happens....oh yeah thats right its called filling a police report for stolen property!! Have you tried this yet? It would be better than arguing about beating him up on the internet
  25. i dont like smelling smoke either, but the thing is its peoples private businesses. If they want to let people smoke in them then fine, its up to them. Many resturants were smoke free before the ban even took place. The smoking ban here is such bullcrap, if i ever meet Pataki im going to kick him in the ball sack. When it first came out there was a bar in Batavia that had "smoke free" nights where if you came they would give you free smokes. They got fined everytime for it, but it was refreshing to see, mkae me want to go there and cough on a few cigarettes.
