00tbanshee Posted May 29, 2008 Report Posted May 29, 2008 i leave in first gear but run a 18 tooth front sprocket.if had the money to put into a billet second i would change my setup to leave in second gear.but like dave said there is alot of different things that decides what gear to leave in Quote
gregrob Posted May 29, 2008 Report Posted May 29, 2008 Your cub was doing more slipping than spinning when you were launching in 4th... Quote
sheerider1026 Posted May 29, 2008 Report Posted May 29, 2008 yea i know, but it was one of those what the hell days.. at first if was grabbing good then started slipping.. lesson learned i guess.. it just spins so bad in 2nd.. maybe i wil just try 3rd gear.. would 3rd be hard on the clutch?? whats a good biting tire to get?? what about zippers?? are they a good drag tire for dirt? Quote
LS1Inferno Posted May 29, 2008 Report Posted May 29, 2008 Ionly launch in second, if the sand is too packed i launch 4th with piped only shee, and gey ass sandstars. Quote
00tbanshee Posted May 29, 2008 Report Posted May 29, 2008 yea i know, but it was one of those what the hell days.. at first if was grabbing good then started slipping.. lesson learned i guess.. it just spins so bad in 2nd.. maybe i wil just try 3rd gear.. would 3rd be hard on the clutch?? whats a good biting tire to get?? what about zippers?? are they a good drag tire for dirt? not sure what the dirt tracks are like there but on our dirt tracks out here ohtsu radial tires seem to work well for everybody.its a honda tire.here is a pic of one http://www.ronniesmailorder.com/eshopprod_..._OHTSU_TIRE.htm also turf tammers with rows cut out work good Quote
shee rips Posted May 29, 2008 Report Posted May 29, 2008 now with 22s and a 15 tooth i only leave in first on the road. on dirt its a toss up between first and second. i dont drag enough to get a routine so its whatever im feeling that particular day Quote
Snopczynski Posted May 29, 2008 Report Posted May 29, 2008 2nd with 14/46 gears, and 3rd with 13/45 gearing. Quote
KaosBanshee44 Posted May 29, 2008 Report Posted May 29, 2008 Always take off in second but like dave said depends on the situation Quote
sheerider1026 Posted May 30, 2008 Report Posted May 30, 2008 not sure what the dirt tracks are like there but on our dirt tracks out here ohtsu radial tires seem to work well for everybody.its a honda tire.here is a pic of onehttp://www.ronniesmailorder.com/eshopprod_..._OHTSU_TIRE.htm also turf tammers with rows cut out work good thats what i am using is the honda radials!! Quote
