so heres the deal im ashamed to admit it but i raced a kawasaki kfx 450 and lost my banshee has a couple of upgrades like boost bottle and itp tires and reeds what sho i do to kick its ass
first of all .. a boost bottle is not a up grade.. throw it in the trash !!!
what pipes do u have... do u still have astock air box ??? timing plate ??
everything is stock except wut i mentioned i have 700 bucks to spend
Trash the "boost bottle" , actually hurts performance and your intake boots, with $700 I would find some pipes off this site for around $300, get some Pods $50, dial in the carbs, so you've spent about $350 to $400 and add a tooth on the front...$12, maybe some VF3s,I just got better reeds,VF3s not worth the money to me, some people swear by them,but you should smoke him. It's a KFX for gods sake. Save the rest for the upcoming port, carbs, Noss head, etc..............
Edited by BaNsHeEs RuLe!
get the T5 pipes with the K&N air filter kit WITH the jet kit and take the top off the box. You will walk on him. Or get used pipes and kit and buy a $300 port job to make a killer package. But it will be tight on 700 bux. My .02 port and fmf pipes.
EVERYONE!!! LOL go to the sales forum
timing plate (set on +4)$35 bucks... get some t-5 or even fmf pipes.... get ur head shaved .030 its like havin a 20-19 dome ( depends on elevation).. pod filters
do u still have the tores on your carbs ???
when u race.. start in 2nd and pin it.. dont let of the gas till ur done racin.. keep it pinned !!!( unless u stand it up )
was that kfx stock?? cuz i find them pretty fuckin slow buddy's bone stock 07 shee smoke the kfx 450 like no tomorowstock for stock
like they said pipes pods timming saved head well jetted and mixed right
Edited by monster_energy06
I call BS, unless they guy on the KFX left the fuel turned off, weighs 400 lbs or doesn't realize there are a few more gears to go after 1st gear.
Bone stock shee is low to mid 30s in HP, 450s are high 30s to low 40s, and weigh 50 lbs less...and have a much better torque curve...
there is no 100% bone stock banshee that will beat any of the current crops of 450s...bone stock vs. bone stock.
Period.
Pipes, air filters, timing and a little more compression will come closer to level the playing field...but it will probably still be a very, very close race. Porting is where the power is...then learning to ride to get the power to the ground via tires, air pressure, gearing and the clutch.
