foxracing350 Posted March 28, 2008 Report Posted March 28, 2008 i put +2 laegers arms on and they will accept grease for like 2 pumps then i cant pump the gun anymore and i know they are not full yet any suggestions?? Quote
Bansh-eman Posted March 29, 2008 Report Posted March 29, 2008 take the zerk off and make sure that the ball bearing move freely in there. Quote
foxracing350 Posted March 29, 2008 Author Report Posted March 29, 2008 how do you get the zerk off? and what ball bearing? Quote
350BANSHEE350 Posted March 29, 2008 Report Posted March 29, 2008 the zirks come off like a bolt i think they are 6mm sockets, not sure, 2 pumps would surprise you of how much grease comes out, i would think that is all it will take, if your getting preasuer on the handle then its full Quote
Dinner Posted March 29, 2008 Report Posted March 29, 2008 the zirks come off like a bolt i think they are 6mm sockets, not sure, 2 pumps would surprise you of how much grease comes out, i would think that is all it will take, if your getting preasuer on the handle then its full Not necessarily true...you can get a few pumps out of a gun, even though there is nothing going into the nipple. Feels like its going places, but it's just filling the greaser hose. So here is my question..after your two pumps and then it gets stiff. When you take the fitting off the grease nipple does grease come out of the grease gun hose, or does some start coming out of the little ball that is in the grease nipple? Quote
Bansh-eman Posted March 29, 2008 Report Posted March 29, 2008 how do you get the zerk off?and what ball bearing? the zerk is the fitting that your pumping grease into. it should unscrew from the arm. in the center of it there is a small ball bearing that keep the grease from coming out. make sure that the bearing moves inside the zerk. you should see grease come out from around the seals once the arm is full. also if you have old grease in the arms it is possible that it is hard and isnt letting the fresh grease into the arms Quote
foxracing350 Posted March 29, 2008 Author Report Posted March 29, 2008 i know what the zerk is lol i just wasnt sure how to take them off and i only got one arm filled with grease where it was coming out the dust caps and there is no old grease in the arms or fittings because they are brand new ill try checking the bearing thanks for the help Quote
Animalman294 Posted March 29, 2008 Report Posted March 29, 2008 To check the ball bearing you should be able to just push on it with something and if it pushes in and back into place it is fine. It only has a small spring behind it to push it back into place. The grease does usually ooze out of the dust covers, but you may need to move the arms to get this to happen because the seals are tight being new and all........... Quote
foxracing350 Posted March 29, 2008 Author Report Posted March 29, 2008 yea i did move the arms up and down like a million times and the only arm i got full was the bottom right one im gonna try to check the bearings tommarow thanks guys Quote
SAVAGE420 Posted March 30, 2008 Report Posted March 30, 2008 (edited) I dont know about you guys, but it takes me more then 2 pumps to get stiff :yelrotflmao: :yelrotflmao: i had too! Edited March 30, 2008 by savage420 Quote
