Ruko Posted March 23, 2008 Report Posted March 23, 2008 I was looking at Fast's site and saw this shift shaft mod they do... I tryed calling him about it but he wasn't in. Anyone have it done or know anything about it?? It's cheap enough but is it worth the time to send my shaft there and wait to get it back? I'm in Canada so shipping can take a while. http://www.farmandsandtoys.com/products.as...CH/TRANSMISSION Quote
shee4speed Posted March 24, 2008 Report Posted March 24, 2008 I personally don't have one but if Jeff has them and talks good about them then their good then. Quote
Toybreaker Posted March 24, 2008 Report Posted March 24, 2008 just buy the mod on a new shifter shaft. that is what i did.. no down time waiting on shipping :thumbsup: Quote
badassbanshee479 Posted March 24, 2008 Report Posted March 24, 2008 used it in my drag bike before I went to an override, worked really well! I also bought the new shaft with the mod already done. he also has an easy shift spring that helps also!! Quote
Ruko Posted March 24, 2008 Author Report Posted March 24, 2008 thx guys... I'll look into the new shaft then, that should work out better for me. Quote
FASTOYS Posted March 24, 2008 Report Posted March 24, 2008 Ruko, they work great! I can modify a new one ( buy a new shaft and get the mod for free) and fire it out with the easy spring and anything else you may need tomorrow if you like ... No down time that way. Usually, if the bike is older than 2000 or so or has a ton of hours on it ... it prolly needs replaced anyway. Give us a holler if needed. Quote
ClimbAnyHill Posted March 24, 2008 Report Posted March 24, 2008 I have it installed on my Banshee along with a Shift Pro kit & shaved star.. works like butter! Also ordered the easy spring but haven't try since Shift Pro comes with their own. I'm pulling the clutch cover off soon & will install Jeff's easy spring! By the look & feel of both I think Jeff's spring will be better for me. I'll report back on that one! Also since you are pulling that cover off I'd suggest ordering a Clutch Pusher + Impeller! Quote
Ruko Posted March 24, 2008 Author Report Posted March 24, 2008 Also since you are pulling that cover off I'd suggest ordering a Clutch Pusher + Impeller! Clutch pusher?? Quote
Toybreaker Posted March 25, 2008 Report Posted March 25, 2008 Clutch pusher?? sometime referred to as a "packard" mod it is a torrington bearing that the clutch pressre plate rides on. I also did the alba shift cam mod... they add a roller bearing to the end that plugs into the output side of the case. if you are splitting the cases that $150 is worth every penny.... that mod accentuates the shift star and the easy spring on the shifter shaft. Quote
Ruko Posted March 25, 2008 Author Report Posted March 25, 2008 sometime referred to as a "packard" modit is a torrington bearing that the clutch pressre plate rides on. ahh... pancake bearing... I get it now... just got everything ordered up, including a pancake bearing :thumbsup: Quote
ClimbAnyHill Posted March 25, 2008 Report Posted March 25, 2008 For shifting upgrades I'd order up the Shift Pro Kit! Bearing rolling over Shift Star is wider with no play & works perfect over a modified Shift Star. Flotek Performance machined my Shift Star for a few bux & came out better than the one sold by Cascade! Quote
monster_energy06 Posted March 25, 2008 Report Posted March 25, 2008 do u have to slip the case for this mod??? ive only played with sled engines never opened a tranny befor Quote
Ruko Posted March 25, 2008 Author Report Posted March 25, 2008 do u have to slip the case for this mod??? ive only played with sled engines never opened a tranny befor no you just have to take off the clutch side cover and slide the shaft out. Quote
monster_energy06 Posted March 26, 2008 Report Posted March 26, 2008 no you just have to take off the clutch side cover and slide the shaft out. right on tx i might look into it Quote
gregrob Posted March 26, 2008 Report Posted March 26, 2008 Where can you buy the shift pro kit? Quote
