Please don't ask unless you really want a item
swinger stock.... all new bearings
stock axle.... straight as an arrow no damage
2 stock airboxes..... 1 as proflo with foam twin air.... 1 is bone stock with lid... both in good shape
foot pegs
propeg nerfs....AC... with custom fabricated support bar (early propegs didn't have the slip tube in the front)
Stock brakes.... front and rear (has block off)
rear brake line
5.9gallon IMS blue tank with elec. intank pump for alky
black tank cover... brand new!!!
Stock pipes
blue race cut.... goes with the oversize tank (cut to match it)
34mm PJ's.... gas
shearer drag pipes... inframe.... REAL carbon fiber silencers.... $400 + shipping
also have the original stingers for the shearers... LOUD
stock clutch cover... brand new
1 +2 full flight a-arm....lower... brand new
1 +2/+1 full flight a-arm.... brand new
Stock reeds and intakes
1 set of pro-X ultra lights .020 pistons with swaintech ceramic domes and PC-9 teflon skirts.... 3.5 hrs like new... Used for 1 ride as a go between motor, before the new +4mm crank and jump to 66mm pistons.
and plenty of other parts for other bikes too!!
Edited by TurboBanshee420
both lowers..... they sent me a mismatch pair...
I think.... well I'm going ot have to look them over before I tell you which one is from what side.
1 is a +2 the other is a +2/+1 forward
Pj's = $200 or $220 with the cable too
IMS tank = $150.... has subaru WRX fuel pump inside.... you will need a fuel pressure reg. Also has a real fuel cell cap installed, instead of the screw on cap.
Clutch cover is bare... just like you get them from yamaha. you will need the parts from your cover...(i.e. vent nipple and pump shaft bearing/seal) $70 is what I paid for the one from direct drive. I would like to get close to that.
anything else....? Lemme know
I will take pics of whatever you guys want to see. I have the next 2 days off finally. First weekend off since christmas
pics of pipes and silencers
It's a OEM '02 black tank plastic cover. from the rad cover back. In other words it is both side panels bewtween the seat and the radiator.
It's in brand new cond...... $40 shipped... depending on where you are.
