climb any hill on E2S has done his with guttering from home depot. That is where I got the idea, really simple and cost me about 6.00 and I made 2 complet sets!!! If you do a search on E2S I am sure it will come up if not PM him he a great help!!!
Good Luck
Forgot the good part. I have dmc 916's, proiflow adapter with prodesign foam filter with the foam wrap. I have the air box lid on with just the snorkel removed.
Thanks again
Alright, so I finally got all my jets ready to go. I have 260,270,280 mains. I have some stock and 27.5 pilots. My ? is, do I go ahead and put the pilots in to or just start with the mains and then go to the Needle and then to the pilots?
Thanks
Somebody has to have an idea!!! DMC said to run 30 pilots with 280 to 300 mains. That sounds a little rich. I was thinking of starting with stock pilots and 270 mains and needle in middle clip.
Thanks
My banshee runs great, except when I ride it for a bit it will idle a little high. It does not do it on start up or if I shut if off then restart it. I am assuming I have an air leak!!! Any suggestions. I found a little antifreeze leaking around trhe head, which I am fixing this weekend. Could this be the problem?????
Thanks
I just ordered a set of DMC 916's. I am 800ft above sea level, 50 degrees in winter and 90 degrees in summer. I run Amsoil 40:1. I am going to run a pro design adapter with foam filter. Where should I start my jetting? (pilot, main, needle)
Thanks
