cato
Everything posted by cato
  1. Did you get my pm??
  2. fast shipping! Thanks for the easy transaction. It is in great shape. It was a pleasure to do bussiness with you. great communication!! Ryan
  3. I will take it, if speedy don't get it. pm sent Thanks
  4. climb any hill on E2S has done his with guttering from home depot. That is where I got the idea, really simple and cost me about 6.00 and I made 2 complet sets!!! If you do a search on E2S I am sure it will come up if not PM him he a great help!!! Good Luck
  5. Forgot the good part. I have dmc 916's, proiflow adapter with prodesign foam filter with the foam wrap. I have the air box lid on with just the snorkel removed. Thanks again
  6. I am 220lbs, 50degrees in winter, 90degrees in summer, right now, 78degrees, 800ft above sea level. Thanks
  7. Alright, so I finally got all my jets ready to go. I have 260,270,280 mains. I have some stock and 27.5 pilots. My ? is, do I go ahead and put the pilots in to or just start with the mains and then go to the Needle and then to the pilots? Thanks
  8. What about wheels??????
  9. He was shocked when I told him I bought a brand new set of DMC's LOL
  10. Somebody has to have an idea!!! DMC said to run 30 pilots with 280 to 300 mains. That sounds a little rich. I was thinking of starting with stock pilots and 270 mains and needle in middle clip. Thanks
  11. My banshee runs great, except when I ride it for a bit it will idle a little high. It does not do it on start up or if I shut if off then restart it. I am assuming I have an air leak!!! Any suggestions. I found a little antifreeze leaking around trhe head, which I am fixing this weekend. Could this be the problem????? Thanks
  12. I just ordered a set of DMC 916's. I am 800ft above sea level, 50 degrees in winter and 90 degrees in summer. I run Amsoil 40:1. I am going to run a pro design adapter with foam filter. Where should I start my jetting? (pilot, main, needle) Thanks
  13. I just ordered a set of DMC 916's. I am 800ft above sea level, 50 degrees in winter and 90 degrees in summer. I run Amsoil 40:1. I am going to run a pro design adapter with foam filter. Where should I start my jetting? (pilot, main, needle) Thanks
  14. There a place called splashndirt.com thats located in canada. I bet they can get one.
  15. cato
    Exhaust
    I should have said I need in frame!! I appreciate the offer
  16. cato
    Exhaust
    Looking for a set of banshee pipes. Would like t5's or dmc 916's. Not looking for fmf's. I am open to about anything. let me know what you got. Thanks
  17. Check your pm's
  18. I have an entire parts blaster minus front fenders and seat. motors good need top end rebuild I got all sorts of wheels and tires. I got wiring harness. Tell me what you need to make a trade? Thanks
  19. It looks like it to me!!!
  20. Fast toys have you had a chance to talk to your supplier? Thanks
  21. I would appreciate it!!
  22. Well, I just got my heart broken. They discontiued the dmc 916's. I tried ordering a new set, with no luck. Does anyone know who might have a set left? Any help would be appreciated.
