Troubledsol
Everything posted by Troubledsol
  1. I bought this off Ebay brand new but it is too small for me. This helmet has not been worn and comes with original box. $150.00 OBO Here is a link to my Craigslist listing with pictures. http://cincinnati.craigslist.org/rvs/1286719343.html Thanks
  2. Me and some friends are headed to the Badlands this Friday morning we will be in the camp grounds. I ride a purple and black shee with paul turners and the wife rides a pink shee with FMFs feel free to stop us and say hi. In the camp grounds we have a lifted blue F-250 pulling a 24 enclosed trailer. Anyone else planning on being there?
  3. 2 Shees 1 Blasty 1 Badger 80 1 CBR600rr which is for sale
  4. Tusk from RMATV they are cheap and work great
  5. Not to knock it but I have a 4 poke weed wacker and it actually does a good job I can hold it a like half throttle the whole time and cut everything If you hold it in 1 hand and throttle it the thing will torque in your hand But I love the Shee I am looking at buying one for the wife the blaster just aint cutting it
  6. I have LSRs and I didnt ream mine I bought the newer ball joints and everything bolts up plus you get the piece of mind of having new ball joints
  7. You can rebuild a stock clutch basket I put the hard ones in my stocker and my wife Blaster BUT you will need to be able to machine it all you do is grind off the 3 rivets pull it apart and rebuild it Put it back together re insert the rivet and weld them back
  8. I ride all trails and hills But I have Paul Turner Mids
  9. If you want to stick with 1 carb you could go to a bigger PWK other than that run what you got if its doing its job I run a single 35 PWK and love it going to try out a 39 PWK soon Unfortunately I wont have any results for a while the weather is a little wet and cold for me till it starts freezing that is A smaller carb would work if you where going back to running 2
  10. I ride mostly tight woods thats why I am liking the single though over the summer I may try and dig up some duals and try them again Thanks for the input
  11. Snop how do they run I love my 35 PWK it was on the shee when I got it though a few guys here talked me into trying stockers again so I bought a cable and a jet kit and all the other stuff I needed I didnt like it at all we tinkered with it for a while and never could get it right and at its best time it was a pig down low I am looking to put this 39 PWK on and do the Port Logic stage 3 and see how she runs If anyone knows for sure what cable to use that would be great Thanks all
  12. I was just curious after doing some searching if anyone is running larger than a 35PWK for a single carb I just got a deal on a bored 39mm PWK and was going to use that and put my 35 PWK on the wifes Blaster after I port it (Port Logic Templates before anyone asks) Also what is the throttle cable I should use for the Blaster with a PWK Thanks
  13. Burgard has +4 on sale $350 I think
  14. Like they said before go for the best bang for the buck watch ebay like a hawk I got my Lonestars for $250 and a set of Works w/ rezies for $135 Just dont rush it
  15. Pics of stock tires
  16. Not a bad start but if you have a Dremel you could notch your stator plate and make it +4
  17. I say skip the VF3 and NOSS head Get you head shaved and get some port work. Then if you havent already mod you stator plate for some more timing. Wait what all do you have done the guys on here can help you WIN
  18. If you were leaking riding wheelies you probably had a bad radiator cap I add a little every few months if that If you were out riding and noticed it was low you only need a little drinking water a your good
  19. Ditch it I ran the overflow hose from the rad straight to the ground and just check my coolant level once in a while
  20. I tried all these methods when I did my rears and nothing worked Took them to the local tire place and 10 minutes and $5 later I left with my new tires mounted
  21. I may be interested a group of my friends are already trying to get a bunch of people to go to Badlands in Attica IN for a long weekend Get some dates together and let us know
  22. Here you guys go someone has to buy this its da bomb Here Shee is
  23. Yep I got em though 1 of the ballasts is bad so I have to order a new one $50
  24. Nope they are the MR11 HID and are way bright and came with a Trail tech rectifier too
  25. I guess he isnt responding on here they sold :biggrin:
