fastquad02blaster Posted January 2, 2008 Report Posted January 2, 2008 Does somebody make a single filter boot that hooks to both carbs? I'm shopping and just wanted to know what everybody runs on their quads and what people like. Quote
fastquad02blaster Posted January 2, 2008 Author Report Posted January 2, 2008 I don't care if I'm running a filter box or not unless you guys suggest otherwise. Quote
bonzai272 Posted January 2, 2008 Report Posted January 2, 2008 I use the Toomey Racing 2:1 filter. The boot is Y shaped to mount to both carbs and then uses a single filter that sits upright. Im happy with it. Quote
Screaming Yellow Zonker Posted January 2, 2008 Report Posted January 2, 2008 I noticed a power gain when I took the toomey off and went to K&N pod filters. Quote
shanYE west Posted January 2, 2008 Report Posted January 2, 2008 For trails I used the box with a pro-flow kit (K&N) with the lid off. If your not going to be gettin mudy or anything like that some clamp on filters work well. Quote
pepehaha Posted January 2, 2008 Report Posted January 2, 2008 What do you guys think about somethink like this http://cgi.ebay.com/ebaymotors/UM-Racing-P...sspagenameZWD1V with this http://cgi.ebay.com/ebaymotors/K-N-ATV-AIR...sspagenameZWD1V and two KN filters? Its an expensive solution, Dunno if it's worth of it Quote
TJ10 Posted January 3, 2008 Report Posted January 3, 2008 What do you guys think about somethink like thishttp://cgi.ebay.com/ebaymotors/UM-Racing-P...sspagenameZWD1V with this http://cgi.ebay.com/ebaymotors/K-N-ATV-AIR...sspagenameZWD1V and two KN filters? Its an expensive solution, Dunno if it's worth of it I've never heard from anyone who's run the aluminum box with dual k&n's but you'd probably be looking at close to $400 for that setup. I don't know if the power gain of running dual filters inside the box would be worth that price. I'd put that $200 for the aluminum box towards something else and just go with the stock box and a sinlge k&n pro flow kit from Noss and maybe that k&n lid if you want the extra protection. Quote
chillls Posted January 4, 2008 Report Posted January 4, 2008 i use the k&n pods :thumbsup: best set up out there even if your ridding in the dirt just put prefilters on them :beer: Quote
TJ10 Posted January 4, 2008 Report Posted January 4, 2008 (edited) i use the k&n pods :thumbsup: best set up out there even if your ridding in the dirt just put prefilters on them :beer: I agree to an extent...from what i've seen and researched, k&n pods are the best setup for dirt or sand riding. I wouldn't suggest them if you're going to be riding in any type of wet or muddy conditions. The risk/reward just isn't there imo. The minimal gain in power isn't worth the price of a new top end (or worse) when you suck water through the carbs. Just my 0.02. Pepe - When I looked at the aluminum box the first time, I thought it was made to run dual k&n's inside. Now when I look at it, I can see that it's made for the single k&n filter like I was suggesting. I'd still go with the k&n pro flow kit like Noss sells and stick with the stock airbox. You'll still save around $100 and the most you'll gain with the aluminum box is cosmetics. Edited January 4, 2008 by TJ10 Quote
fastquad02blaster Posted January 7, 2008 Author Report Posted January 7, 2008 I ordered the k&n pods with outerwears. I ordered vforce3 reeds and my toomeys are on the way also. Quote
Justintoxicated Posted January 7, 2008 Report Posted January 7, 2008 I agree to an extent...from what i've seen and researched, k&n pods are the best setup for dirt or sand riding. I wouldn't suggest them if you're going to be riding in any type of wet or muddy conditions. The risk/reward just isn't there imo. The minimal gain in power isn't worth the price of a new top end (or worse) when you suck water through the carbs. Just my 0.02. Pepe - When I looked at the aluminum box the first time, I thought it was made to run dual k&n's inside. Now when I look at it, I can see that it's made for the single k&n filter like I was suggesting. I'd still go with the k&n pro flow kit like Noss sells and stick with the stock airbox. You'll still save around $100 and the most you'll gain with the aluminum box is cosmetics. True but foam filters plug up way too fast in the dunes. They filter too well... Quote
gumby6t9 Posted January 7, 2008 Report Posted January 7, 2008 True but foam filters plug up way too fast in the dunes. They filter too well... Foam filters filter too well??? Do you mean that they attract and retain too much sand at the dunes? Quote
Justintoxicated Posted January 7, 2008 Report Posted January 7, 2008 Foam filters filter too well??? Do you mean that they attract and retain too much sand at the dunes? Well its been proven that a quality foam filter will filter particles better than K&N. K&N and other mesh filters do not filter out small particles very well. However Foam is more restrictive and yes it retains too much junk, and plug sup quickly. It would probably be better for your motor to run a foam filter in the dunes, but you might have to clean it after every ride to maintain performance... Despite K&N's not being great filters they work well enough on the banshee when you add outerwears it's not like a car where you have to have the motor last you 100's of 1000's of miles, these motors don't last that long anyways before needing a rebuild and the K&N filters well enough to now blow up your motor so long as you maintainn and replace them every so often. I wonder how well those dry filters like the AEM would work on the banshe?. NAH screw that with all the oil from the carbs backspray and the expense of cleaning them, probably not worth finding out. Gotta stick with Foam or Gause... Quote
TJ10 Posted January 8, 2008 Report Posted January 8, 2008 True but foam filters plug up way too fast in the dunes. They filter too well... I was suggesting that if fastquad rides in mud or water, he should run the k&n proflow over pods. I never suggested that he run a foam filter though I do agree that they do filter particles better than gauze. Quote
Washburn Posted January 8, 2008 Report Posted January 8, 2008 That setup is way to much cash. For a drag racer that has to have every little bit of extra power then yeah but thats not a justified purchase for just riding. That K&N Airbox lid is over priced too. I use my stock lid with 12 1" holes cut in and I have 1" mini foam filters put in for a little more airflow. I also run a 2:1 uni foam filter with the plastic cage that seats rite in the airbox for as much filtration as I can get because I run through alot of water/mud puddles. Its imposible to avoide them and while I could squese a few more HP with a K&N setup its not worth the risk to reward ratio. For sand I would use the K&N Pods with outerwares for better airflow. Quote
