wacko2000 Posted January 1, 2008 Report Posted January 1, 2008 Exactly what it says above...I went riding, came home washed the shee then I took her for alittle spin around the block, I shifted from 1st to 2nd and hit the throttle, before I new it I was on my ass and the shee flipped over... Can someone tell me why this happens bc This isnt the first time the throttle has gotten stuck on me..... Please help....This shit sucks.. My ass is killing me I cant even sit down.... Quote
zach45 Posted January 1, 2008 Report Posted January 1, 2008 (edited) air leak somewhere.... i had problem first time i went to coal hills with mj.... we fixed it tho np... anything happen to the bike joey? Edited January 1, 2008 by zach45 Quote
shee rips Posted January 1, 2008 Report Posted January 1, 2008 if it was cold outside the water could have frozen the slides open. mine froze on me one time in the throttle assembly on the handlebars. if you have the tors removed i heard that it will stick if you tighten the carb tops too tight. hope that helps. Quote
wacko2000 Posted January 1, 2008 Author Report Posted January 1, 2008 I dont no bc I rode the bike all day with no problems at all...I was thinkin that maybe some dirt or sand got in there through the air filter or something...I Zack where was you air leak? How did you find it and how did you fix it? what sucks is that i never ride my shee with out the kill switch, I mean NEVER and the one time I dont look what happens..That switch has saved me so many times.... Zach I bent the wheelie bar, and bent an a-arm.... no biggie if you would have seen it you would understand how lucky i got...The new a-arm is in the mail already.... Mike at ASR sent me one, no questions asked, he was laughin when i told him what happened... Quote
sheerider1026 Posted January 1, 2008 Report Posted January 1, 2008 i have had that problem .. i have heard that wet throrrle cables on banshees tend to stick.. i always hang my cables up and oil them and let them soak for an hour or so prior to instaling.. last longer and are smoother.. Quote
zach45 Posted January 1, 2008 Report Posted January 1, 2008 mine were in the carb boots... few zip ties fixed it... yea mike at ASR is a good guy... Quote
trail rider Posted January 1, 2008 Report Posted January 1, 2008 (edited) Exactly what it says above...I went riding, came home washed the shee then I took her for alittle spin around the block, I shifted from 1st to 2nd and hit the throttle, before I new it I was on my ass and the shee flipped over...Can someone tell me why this happens bc This isnt the first time the throttle has gotten stuck on me..... Please help....This shit sucks.. My ass is killing me I cant even sit down.... you got water in your carbs causing them to stick open. just take compressed air and go over the carbs really well after you wash it off Edited January 1, 2008 by trail rider Quote
wesw Posted January 1, 2008 Report Posted January 1, 2008 you can pull the slides out, take some scrotch brite or emery paper and remove the casting edges on the slides it will help them slide easier and not stick sometimes. Quote
meanv10 Posted January 1, 2008 Report Posted January 1, 2008 I dont no bc I rode the bike all day with no problems at all...I was thinkin that maybe some dirt or sand got in there through the air filter or something...I Zack where was you air leak? How did you find it and how did you fix it?what sucks is that i never ride my shee with out the kill switch, I mean NEVER and the one time I dont look what happens..That switch has saved me so many times.... Zach I bent the wheelie bar, and bent an a-arm.... no biggie if you would have seen it you would understand how lucky i got...The new a-arm is in the mail already.... Mike at ASR sent me one, no questions asked, he was laughin when i told him what happened... Might be dumb, but like a tethered kill switch? Quote
00tbanshee Posted January 1, 2008 Report Posted January 1, 2008 you might want to just try changing your throttle cable.mine did it one time and it was right before the throttle cable broke. Quote
Dinner Posted January 2, 2008 Report Posted January 2, 2008 My slides kept sticking open the other afternoon I was riding. As mentioned earlier...it was probably the water/condensation in your carbs. My shee has been sitting in the open cold air due to my shop under construction. Right carb slide kept sticking every now and then so I had to blip the throttle to have it come back down. Once the moisture was gone they didn't stick anymore... Quote
[email protected] Posted January 2, 2008 Report Posted January 2, 2008 happend to me but the problem was , the carb tops came like slightly loose where the wire goes in... i was about 50mph on a gravel road with a canal next to me... I just didnt want to dump the bike in the canal trying to hold on and turn the bike off.. Quote
wacko2000 Posted January 2, 2008 Author Report Posted January 2, 2008 you can pull the slides out, take some scrotch brite or emery paper and remove the casting edges on the slides it will help them slide easier and not stick sometimes. Some of the slide is black and some isnt, should I clean up the whole slide? thanks guys for all the info... The throttle cable is new...TORs is removed.. Quote
. Posted January 2, 2008 Report Posted January 2, 2008 you just washed your bike, it was below freezing, and you were moving through the air. That little bit of residual water froze your throttle cable, or your slides in the carb body. How well oiled is the cable? Thats more likely the culprit. Just dont rip your bike after you wash it, in the freezing Quote
wacko2000 Posted January 2, 2008 Author Report Posted January 2, 2008 Honestly I have never oiled or lubed the cable, maybe i should take it off and do that.. Quote
