nitroburner13 Posted December 13, 2007 Report Posted December 13, 2007 my buddy has a 1988 warrior that he recently put a 96 motor in. we got the bike to idle good but as soon as you barely crack the throttle open it just flat dies. ive worked on warriors a lot but have honestly never run into this before. i dont think its the carb because i went through and there is nothing wrong and everything is clean and clear. any ideas? we want to get it running for a trip in the next 2 weeks so any help would be amazing. thanks for the help guys,adam Quote
flattrakker Posted December 13, 2007 Report Posted December 13, 2007 my buddy has a warrior.. never told me of anything like this happening to his so im no help.. sounds electrical.. does it like cut out or just die immediatly? Quote
nitroburner13 Posted December 13, 2007 Author Report Posted December 13, 2007 thats what i thought too because of the way it dies. it just cuts out and shuts off. i need to go pick up a clymer and start thumbing through i guess. if anyone has any ideas ill try anything. Quote
Screaming Yellow Zonker Posted December 13, 2007 Report Posted December 13, 2007 does it seem like it's running out of fuel? Or it just stops? Quote
ohiobanshee Posted December 13, 2007 Report Posted December 13, 2007 Did you change the flywheel and stator from the old motor to the new one? If you didn't you will have to,they have different pickup points. Quote
jbooker82 Posted December 13, 2007 Report Posted December 13, 2007 You might check the stator out. Get a manual and see what the specs are for the stator. Quote
nitroburner13 Posted December 13, 2007 Author Report Posted December 13, 2007 the stator and the cdi are from the 96 motor. ill am going to get a clymer soon and ill check it out just to make sure. Quote
Hilarious Posted December 13, 2007 Report Posted December 13, 2007 Just a long shot but, there is a ground wire up around the reverse selector switch, lever dealy. Check that out and clean it up. I had that problem with mine and i also had a wire ground out near the steering stem. Check out all your wiring around the frame. :shrug: :beer: Quote
theshee Posted December 13, 2007 Report Posted December 13, 2007 On the warrior my dad hadm the intake boot between the carb and the motor cot a small crack in it. It did the same thing, idled fine, but would die the second you tried to give it gas, changed that rubber boot and it was fine after that. May want to check it out. We would have never noticed it, but we went to work on it at night and started it in the shed and when my dad gave it gas i just happen to look right there and noticed some fire through the crack. Quote
fox_forma Posted December 15, 2007 Report Posted December 15, 2007 i had 2 warriors a few years ago that did the same thing, it had to do with the reverse switch on one of them and the p-brake on the other. I remember having to go to the wires under the nose piece near the bars and splicing the brown and yellow wire together to solve the issue. I cant be positive if those are the right colors but I believe they are. Either way pull the fenders off and look at the wires and see if anything is cut or spliced. Quote
DuneRookie Posted December 17, 2007 Report Posted December 17, 2007 It can certainly be a number of things. I would also check your air screw on the bottom of carb. If turned too far out it will also cut out and die as you described. Should only be 1 1/2 to 2 turns out max. Good luck. Quote
