Ok so He pulled the clutch and rode it for 1/4 mile or so then came back Like your clutch broke.:mad: WHAT?!? I grabed the lever and ROCK SOLID!!:mad: So I tore the cover off and as your guessed the ball and rod are one so i got them out now my lever is still stuck!! I can see on the ball here it tried to weld on both sides!! Any ideas on how to fix this? NE ONE IN HOUSTON TX WANNA COME HELP? I have never split the cases before and I dont want to fuck this up. please help. PICTURES of what your sayin will HELP LOADS!!
Edited by TexasBansheeMan
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
Anyone got any ideas? I can get a magnet on the ro but it will only move bout a 1/8 inch. I can feel it clickin in the clutchcable when i move the rod. PLEASE HELP!!!
BigRed350X has a case splitting 'how to'...I will try and find it. With the 'how to' and a manual, you will find that it is not bad at all.
EDIT: HERE it is...this should help very much if you need to split the cases to solve the problem... :confused:
Thanks BigRed350x!! :thumbsup:
Edited by BellicoseBanshee
THANX MAN :biggrin: :thumbsup: I started Trying to get the Aligenment lever out of the case and no such luck. Its hung up harder tha a $2 buk f@*k in china town! ANY IDEAS i have to get this out before i can split the cases. There is no way it can be this hard!!
1. Dont let neighbors ride your banshee
2. Buy a Clymers Manual
3. Buy a pancake bearing
4. Enjoy the time spent with your machine while splitting the cases and learning what makes a banshee work
There is no easy way. Just get'r done so you can go ride again.
ok so I have been hard at it and i still cant get the dajustment lever out of the case. I can get it to come up some than its hung. Is orentation important? It will move just the smallest bit back and forth but when i come up on it It just hangs up. Anyone ever faced this?
P.S. I have been at it with.. prybar,hammer,18 nail bar, screwdrivers. I am no puss I got bout a buc ninty five on the hoof so Its GETTN BEAT ON.
will the clutch arm twist? if so, the rod is probably all fucked up in there and not letting the arm come out. if it wont twist you could have welded the rod to the clutch arm. either way its gonna be a motherfucker gettin it out.
