I'm having a problem with my bike..right where the muffler connects its leaking an oil like substance all over the bike when i come back from a short ride there is black oil all over the back of it..what causes that?
its where the silencer connects to the pipe..and instead of starting a new thread how can i tell what jets i have in my carbs? i think it is running too rich cause i keep fouling out plugs after about an hour of run time one cylider stops firing so i take the plug out and its got alot of carbon on it and there wet
a set of plugs well do you a year or so
to check you main jet which is probably hy its way rich all you have to do is pull the carbs and take the bowls off and in the middle there is a gold hex shape with a hole its you main jet it well have a number on it and the higher the number the richer it gets
you deffinatly need to rejet and get some rubberseals to go over the exhaust tubes connecing the to nicely and that well sto your leak
good lucky
My bike has t5's, v-force3's and stock airbox/no lid with a uni foam filter. I run a 280 main at sea level. Your k&n pods are probably going to need another couple of jet sizes over that. I would say you would be in the 300 range on the main jet. And as far as the timing goes, When I advanced mine 4 degrees, i didn't have to change jetting at all.
mine spits out a little from tha end of tha mufler(were tha smoke comes out from)
sa3ood :evil:
rich too much fuel for whats getting burnt. the unburnt gets blown out the exhaust. If your happy the way it runs its fine, you will probably be losing a little performance, maybe foul plugs sooner and will need to replace silencer packing sooner.
it runs really good but fouls plugs like crazy like after a 20 min ride and it smokes really really bad
Edited by 13bturbofc
