BSHEE400 Posted October 7, 2007 Report Share Posted October 7, 2007 what is better to fit for smoother shifting for mx style riding, a modded shift star or the shiftpro kit (small arm with spring and roller) I've already bought the kit off ebay but should i try find a shift star too. any advice appreciated Quote Link to comment Share on other sites More sharing options...
platinumjason Posted October 7, 2007 Report Share Posted October 7, 2007 I run both together, they work very well. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted October 7, 2007 Report Share Posted October 7, 2007 Add a Mugura Hydraulic clutch lever :thumbsup: Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted October 7, 2007 Author Report Share Posted October 7, 2007 I run both together, they work very well. where can i get the modified star Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted October 7, 2007 Author Report Share Posted October 7, 2007 Add a Mugura Hydraulic clutch lever :thumbsup: i recently fitted the hydraulic clutch and i absolutely love it Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted October 7, 2007 Report Share Posted October 7, 2007 where can i get the modified star Site sponsor FAST Racing has them! Quote Link to comment Share on other sites More sharing options...
MDS2106 Posted October 7, 2007 Report Share Posted October 7, 2007 Either one works well for smooth shifting,but the shift pro doesn't help you find neutral like a modded shift star. Quote Link to comment Share on other sites More sharing options...
brian Posted October 7, 2007 Report Share Posted October 7, 2007 I heard from another guy that used both mods at the same time that they didn't work very good together. Made shifting so easy that it was changing gears when hitting big bumps. I dont know ? :shrug: Thats what I was told. Quote Link to comment Share on other sites More sharing options...
sek2dts Posted October 7, 2007 Report Share Posted October 7, 2007 i used both together with the stock shifter and it was alot better, then i bought a prodesign shifter and now it really feels good. the stock shifter flexes to much. with the 3 things combined its in my opinion its night and day difference for a banshee. Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted October 7, 2007 Report Share Posted October 7, 2007 I have the modified Shift drum (alba sells them) and the shifter star. Shift star helps a bunch but that shift drum makes a night and day difference. Every banshee i build is going to get one of those! Quote Link to comment Share on other sites More sharing options...
brian Posted October 7, 2007 Report Share Posted October 7, 2007 i used both together with the stock shifter and it was alot better, then i bought a prodesign shifter and now it really feels good. the stock shifter flexes to much. with the 3 things combined its in my opinion its night and day difference for a banshee. Not tryin to argue with you. But you don't have problems with it jumping gears when you skippin whoop tops ? I was thinking of using both together, but I dont want the fucker downshifting on me when I am really hammering the whoops. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted October 7, 2007 Report Share Posted October 7, 2007 I have the modified Shift drum (alba sells them) What's the Mod on the drum? Quote Link to comment Share on other sites More sharing options...
sek2dts Posted October 7, 2007 Report Share Posted October 7, 2007 (edited) Not tryin to argue with you. But you don't have problems with it jumping gearswhen you skippin whoop tops ? I was thinking of using both together, but I dont want the fucker downshifting on me when I am really hammering the whoops. never once had a problem with it jumping out of gear. if u look at the design of it the one place it can jump out easy is neutral. when its in gear the roller sits in the belly of each star. its only suppose to change gears easier when the shifter is pushed up or down beacause of the rounded corners. if your not hitting the shifter it def should not be poping out of gear. Edited October 7, 2007 by sek2dts Quote Link to comment Share on other sites More sharing options...
RZBansheeMan Posted October 7, 2007 Report Share Posted October 7, 2007 I could only imagine, with the fore mentioned mods in conjunction with the "RZ" shift forks and drum, a person would have one "kick ass" shifting transmission. Quote Link to comment Share on other sites More sharing options...
