peterlocal22 Posted October 7, 2007 Report Posted October 7, 2007 didnt get much of a response so i figured i would try in this dept. i messed up. had my clutch cover polished then i put a new billet impeller in because i figured i may as well since i have the cover off. anyways put it all back together with new gaskets. just remembered i forgot to oil the bearings that the impeller goes into. book says to use transmission fluid. think this will be a problem. anyone else run into this problem? should i take it apart again and oil the bearings before i fill the bike up w anti freeze and oil or should i be ok? thanks Quote
dajogejr Posted October 7, 2007 Report Posted October 7, 2007 didnt get much of a response so i figured i would try in this dept. i messed up. had my clutch cover polished then i put a new billet impeller in because i figured i may as well since i have the cover off. anyways put it all back together with new gaskets. just remembered i forgot to oil the bearings that the impeller goes into. book says to use transmission fluid. think this will be a problem. anyone else run into this problem? should i take it apart again and oil the bearings before i fill the bike up w anti freeze and oil or should i be ok?thanks You're fine...don't sweat it... Within seconds of starting up tranny fluid will splash up there and lube it...no big deal. Quote
peterlocal22 Posted October 7, 2007 Author Report Posted October 7, 2007 You're fine...don't sweat it...Within seconds of starting up tranny fluid will splash up there and lube it...no big deal. Thanks dajoger i appreciate it. i didnt even think of that. i dont know where my mind is today. thanks again Quote
locogato11283 Posted October 7, 2007 Report Posted October 7, 2007 Thanks dajoger i appreciate it. i didnt even think of that. i dont know where my mind is today. thanks again its sunday, dont worry about it. sundays always fuck me up too.. something about wishing it was friday again and realizing its monday tomorrow and i gotta go back to work. Quote
brian Posted October 7, 2007 Report Posted October 7, 2007 its sunday, dont worry about it. sundays always fuck me up too.. something about wishing it was friday again and realizing its monday tomorrow and i gotta go back to work. I'm with Loco ! I hate that feeling ! Quote
vitovito240 Posted October 7, 2007 Report Posted October 7, 2007 dont mean to hijack your thread peter but i just installed my new impeller and had a question. once the new impeller is in and the clutch cover is back on the bike should the new impeller still spin freely? or should it not move when you try an turn it by hand? Quote
Bansh-eman Posted October 7, 2007 Report Posted October 7, 2007 it should spin but not freely, it should have some tension on it. Quote
swrbansheeboy Posted October 8, 2007 Report Posted October 8, 2007 dont mean to hijack your thread peter but i just installed my new impeller and had a question. once the new impeller is in and the clutch cover is back on the bike should the new impeller still spin freely? or should it not move when you try an turn it by hand? well since the gear couples it to the end of the crankshaft then it shouldnt spin unless the crank is spinning. by any chance did you forget to put the pin in that keeps the drive gear from spinning on the impeller shaft? if it's spinning without turning the crank i'd say theres a problem... http://parts.yamaha-motor.com/partimage.gifx?d=12622,2,0 Quote
