I hate to sell this thing, but it's got entirely too much dust on it.
Shaffer Chromoly LT chassis, swing arm and +4 A-arms(I think)
Elka quad rates, SSD front and rear
Passion built 12 port 4mil RZ motor
The motor has RZ jugs and head(cut for 110)
Banshee cases
RZ shift forks and drum
Banshee clusters
Fast Racing clutch with pancake bearing(Basket, fibers, steels, pressure plate, inner hub all have about ten hours on them)
Prodesign billet intakes
Lectron 32mm carbs
Rocket pipes
YZ filter with custom Airbox
Quick change clutch cover
Durablue axle
Hubs to convert Honda spline to Banshee bolt pattern(expensive durablue part)
Durablue Sprocket and brake hubs
Shaffer Chromo stem with LS antivibe clamp
The bike is awesome, it's hard to describe unless you have ever ridden one.
The motor makes hp around low 70s when tuned right, but has an insanely broad powerband from the Powervalves.
The chassis is the most stable Banshee chassis I have ever ridden.
Reduced: 85% of original size [ 600 x 400 ] - Click to view full image
The chassis is built to work together, but it can be taken apart if anyone is interested in the parts.
You know if the stem will work with a stock shee frame or is it only for the 250r geo? If it works for the stock frame if you could PM me a price that would be awesome.
Good luck on your sale, that's one awesome bike, I'm sure somebody will really enjoy the parts!
As far as Banshee parts go, it would be the plastics, motor, exhaust and rear tires. Evreything else is either just for this frame or for the most part this thing is all Honda.
how much for complete bike?
where you located? how far you willing to drive to meet?
$6000 and it's gone right now. I can meet you half way, Missouri isn't that far.
