the plate should only be 2mm thick.....and you'll need 795 series pistons for the longrod...
the right way to do it would be to have your cylinder ported for the crank, have the 795 series pistons put in of rthe long rod, and then have a coolhead with stroker domes so you won't need the spacer plate at the bottom of the cylinders..
i fthose companies say what they gave you is right, then run it. i'd just kick it over on the bench by hand to make sure the pistons don't hit the head and check you compression to see what kind of gas to run. oh and a leak down test. then if it blows up, its not on you...
here's the crank:
http://www.hotrodsproducts.com/index.cfm?f...p;productid=121
here's the pistons:
http://www.hotrodsproducts.com/index.cfm?f...p;productid=128
here's the stroker plate:
http://www.vitosperformance.com/atv_parts/...=200&page=1
now hotrods makes a stroker gasket kit for this crank, but its for an oem head and i have a cool head. so what i think is that the gasket kit acts just like the stroker plate so it should work, right?
Do not use the stroker plate or the thick gasket !
Get the 4mm "hot rods" long rod crank, and get the "795" pistons. Have your cylinders ported for the additional stroke and new engine displacement, and then get some stroker domes for your cool head. This is the proper way do a 4 mm stroker.
here's the crank:
here's the pistons:
if you buy that crank form that website you are WAY over-paying.
go to www.farmandsandtoys.com and give jeff a call, and tell him what you want. plus, if you get a port job to match the crank, you'll gain WAY more power than just the crank by itself..
yes you would be over paying.
crank.400 to 450
pistons with gaskets.165/170
cut domes.60
if you do the math right with the money youill be saving you can get your jugs ported.by the way you still need barings,seals,shift fork.on and on and on
they have them on ebay, or you can get them from almost any builder... you need to decide what type of fule you want to run and then figure out what size for your elevation would achieve that...
well the pistons already came in, but i am going to get the cut domes instead of the stroker plate. does anyone know where i can order a set?
Give noss machine a call. They make all those custom domes.
those plate r junk i had my run with them and then had john at sand toys do the stroker the right way if have a little extra cash do it the right way and get rid of those shity ass plates or thinck ass gaskets
Do a search on how to meaure the squish. If you get some "off the shelf" stroker domes you will need to measure to make sure it is correct, between .030" and .035". Less than .028" and you may have detonation or interference issues more than .040 and you start loosing power. If you give NOSS the base gasket thickness he should be able to get you prety close, if you install the cylinders and measure the deck height (distance from top of cylinder to top of piston, piston will stick out above the cylinder = negative deck height) then NOSS can make you some domes that are right on the money.
