KyleMan-shee Posted September 7, 2007 Report Posted September 7, 2007 (edited) Hey guys, my banshee is running 108psi on one cylinder and 110 on the other... So it's about rebuild time isn't it? And if so, do i just need rings and gaskets or do i need pistons as well? Edited September 7, 2007 by KyleMan-shee Quote
theshee Posted September 7, 2007 Report Posted September 7, 2007 If you are going to put a new top end in, you will need pistons (comes with rings), a bore/ hone, and a new head gasket. Quote
Bansh-eman Posted September 7, 2007 Report Posted September 7, 2007 108 and 110 are fine for an aged stock motor. thats not really all that bad... Quote
FasterThanU90 Posted September 7, 2007 Report Posted September 7, 2007 need to have the bore measured if in spec u can get away with a ball hone and rings Quote
BellicoseBanshee Posted September 7, 2007 Report Posted September 7, 2007 If it needs to be bored, you will need: pistons, rings, wrist pins, pin bearings, head gasket, and base gaskets. This kit comes with everything you need: Wiseco Piston Kit. Really good price on parts for a complete top-end rebuild. Quote
trex banshee Posted September 7, 2007 Report Posted September 7, 2007 If it needs to be bored, you will need: pistons, rings, wrist pins, pin bearings, head gasket, and base gaskets. This kit comes with everything you need: Wiseco Piston Kit. Really good price on parts for a complete top-end rebuild. damn that is a good price :biggrin: Quote
