Hey guys, my banshee is running 108psi on one cylinder and 110 on the other... So it's about rebuild time isn't it?
And if so, do i just need rings and gaskets or do i need pistons as well?
Edited by KyleMan-shee
If you are going to put a new top end in, you will need pistons (comes with rings), a bore/ hone, and a new head gasket.
need to have the bore measured if in spec u can get away with a ball hone and rings
If it needs to be bored, you will need: pistons, rings, wrist pins, pin bearings, head gasket, and base gaskets. This kit comes with everything you need: Wiseco Piston Kit. Really good price on parts for a complete top-end rebuild.
damn that is a good price :biggrin:
