yfz450 Posted March 15, 2007 Report Posted March 15, 2007 Ok, anyone know make/model on these? He does want an arm & a leg for shipping. Ebay Link Quote
91banshee Posted March 15, 2007 Report Posted March 15, 2007 Ok, anyone know make/model on these? He does want an arm & a leg for shipping. Ebay Link DG pipes Quote
FireHead Posted March 15, 2007 Report Posted March 15, 2007 Ok, anyone know make/model on these? He does want an arm & a leg for shipping. Ebay Link See if you can get a better picture of them. I am not sure they are DG pipes. They look like they have weld seems that are idicative of a hand coning style of construction . They might be an old FTZ or LRD pipe. Can you email the seller and ask? :geek: Quote
atvcraze Posted March 15, 2007 Report Posted March 15, 2007 they look like the ones i have on my machine the guys told me what they are but i forgot. Quote
dajogejr Posted March 15, 2007 Report Posted March 15, 2007 The expansion chamber seems a little large to be DG....IMO. I think I see cone welds there too... YFZ....are you interested in some FMF pipes? PM Jankab.... Quote
Snopczynski Posted March 15, 2007 Report Posted March 15, 2007 Looks like a set of pwer pro pipes (they make pipes for Trinity). You can custom order certain exp. chamber sizes, so they look like a one off set. Quote
djackbanshee Posted March 16, 2007 Report Posted March 16, 2007 That looks like Dynoprt twin pipes to me Quote
FireHead Posted March 16, 2007 Report Posted March 16, 2007 Looks like a set of pwer pro pipes (they make pipes for Trinity). You can custom order certain exp. chamber sizes, so they look like a one off set. That is a good point they could be Power Pro in-frames. In fact I may change my guess to that. What pipes do Power Pro make for Trinity? I thought Trinity had their papies made by some stamping house up in NorCal? Quote
Snopczynski Posted March 17, 2007 Report Posted March 17, 2007 (edited) That is a good point they could be Power Pro in-frames. In fact I may change my guess to that. What pipes do Power Pro make for Trinity? I thought Trinity had their papies made by some stamping house up in NorCal? I thought trinity had a cookie cutter pipe made by power pros that they used on all there ported bikes. Here is a cookie cutter banshee pipe from power pros. Biggest thing to note usually between manufacturers is usually the head pipe design. No matter what the pipe is built to do (except for drastic powerband changes), it is usually the same shaped headpipe leading up to the exp. chamber. Edited March 17, 2007 by Snopczynski Quote
FireHead Posted March 17, 2007 Report Posted March 17, 2007 I thought trinity had a cookie cutter pipe made by power pros that they used on all there ported bikes. Here is a cookie cutter banshee pipe from power pros. Biggest thing to note usually between manufacturers is usually the head pipe design. No matter what the pipe is built to do (except for drastic powerband changes), it is usually the same shaped headpipe leading up to the exp. chamber. You are correct. Trinity does not have any hand coned pipes. :thumbsup: Quote
woodro77 Posted March 17, 2007 Report Posted March 17, 2007 the silencers look like old fmfs yes they do , i have a set of older fmfs in my shop and they look just like them , except with the ends cut off Quote
Snopczynski Posted March 17, 2007 Report Posted March 17, 2007 That oval silencer has actually been used quite a bit. FMF, LRD, power pro, and answer all use those designs over the years. Sometimes the silencers will interchange from pipe to pipe also. Quote
djackbanshee Posted March 18, 2007 Report Posted March 18, 2007 Look closely guys at the pipes they have been hand rolled u can see that a bit in the middle part Quote
Crazy05 Posted March 19, 2007 Report Posted March 19, 2007 They look like they are part stamped, part hand made. I would just get some proven pipes for your aplication. Quote
