FasterThanU90 Posted January 13, 2007 Report Posted January 13, 2007 What elevation and mains are u guys runnin Quote
bansheeseat$$ Posted January 13, 2007 Report Posted January 13, 2007 (edited) I'm runnin 172 mains with dial a jets out one turn. EDIT:4500 ft Edited January 13, 2007 by bansheeseat$$ Quote
BigRed350x Posted January 13, 2007 Report Posted January 13, 2007 7500ft elev. most of the time. Keihin Carbs I believe I had like 155's to 160's in mine most of the year with a 4mil cub. Quote
moneybags Posted January 13, 2007 Report Posted January 13, 2007 155 main jet and 55 pilot. Clip in midil poshion. Still pritty rich at sea level Mods are in my sig Quote
locogato11283 Posted January 15, 2007 Report Posted January 15, 2007 10mm cub rockets k and n clamp ons v force 3 39mm pwk -- 160 main, 45 pilot 1000 feet above sea level. Quote
dajogejr Posted January 15, 2007 Report Posted January 15, 2007 10mm cubrockets k and n clamp ons v force 3 39mm pwk -- 160 main, 45 pilot 1000 feet above sea level. Similar... my old motor, 4 mil, Shearers, K&N Pods, 35PWKs, 500 to 750 feet above, I ran 150 mains, 48 pilots, CEL needles, mid clip. When it was cold @ the dunes, I opened my powerjets to 1.0 turn out to be on the safe side...ran good!! Quote
FasterThanU90 Posted January 16, 2007 Author Report Posted January 16, 2007 hmm im at 175 at sea level plugs are a little dark felt like i had a flat spot on top tho tried sum 110 mix a little maybe that was why with not enough time advance Quote
locogato11283 Posted January 16, 2007 Report Posted January 16, 2007 you need to go down with your mains. how dark are the plugs?? putting a higher octane fuel in isnt going to fix the problem.. Quote
s-540 Posted January 16, 2007 Report Posted January 16, 2007 421 cub , shearers, kn,drag port 1500 ft 162main 45 pilot Quote
FasterThanU90 Posted January 17, 2007 Author Report Posted January 17, 2007 "you need to go down with your mains. how dark are the plugs?? putting a higher octane fuel in isnt going to fix the problem.." yea it is running a little rich wanted to see what everyone else was running to get a ballpark. plugs arent that dark. i kno i was saying that because of the higher octane thought that was causing it to act up on top is that just beacause of not enough timing? Quote
locogato11283 Posted January 17, 2007 Report Posted January 17, 2007 "you need to go down with your mains. how dark are the plugs?? putting a higher octane fuel in isnt going to fix the problem.." yea it is running a little rich wanted to see what everyone else was running to get a ballpark. plugs arent that dark. i kno i was saying that because of the higher octane thought that was causing it to act up on top is that just beacause of not enough timing? no. you can run 110 octane fuel straight and set your timing at 0. when you go up with your timing tho you have to run the higher octane fuel. what octane and mix of fuel are you running? you might be able to up the timing some. but id get your jetting issues solved first. Quote
