anyone remeber off the top of thier head which two wires in the harness you splice to make your lamps run high beams all the time or with a toggle between?
or it mght be 3 wires i cant remember
Edited by Bansh-eman
black and yellow at the lights... but im talking about at the switch... when you crack it open i want to say theres 3 connections for high beams...
by that schematic it looks like it would be the yellow the blue and the yellow/red for all the time high beams
ok so i got it narrowed down some... i need the solid yellow (high beams)and the solid blue (tail light) on one side of the switch....
then the other is the yellow with red stripe ( power wire )
i cut the green being its lowbeam and i dont need it...
now i got 2 questions...
i got a black wire for ground... im assuming i dont need it?
also the yellow with red stripe at the end splices and adds a sloid red wire... anyone know what that ones for?
