floydfan_90
About floydfan_90
  • Birthday 04/29/1988
Contact Methods
  • Website URL
    http://
    Eau Claire,WI
  • Interests
    riding,fabrication, building and driving trail trucks
    90' with A-arm converson +2 +1, works tripple rate front shocks,works rear shock,RaZer MX's on polished dugles rims,K&N pod filters,30mm PWK's,pyrimid reeds,MX port,4mm stroker crank,wisco pistions,FMF fatties,
floydfan_90's Achievements
  1. I think im lacking power I just finished my build about a month ago and finally got to run my first drag race (on asphalt) it was a yfz with a pipe and filter and cam and I beat him of course but not by nearly as much as I think my shee is capable of. Gearing or bump my compression up? Also it will barly bring the front end up in fifth im new to the banshee world quads for that mater, but that doesn
  2. I need alignment specks for a banshee caster, camber, toe and ideal Ackerman angle (toe out on turn).
  3. just grab a hammer and a chisel its free and works well BTW im a heavy diesel mechanic so i have dealt with my fair share of stubborn nuts and bolts.
  4. Ok finally got er going after like 5 months of dumping time and money in to my new obsession and I have a jetting problem. My mods are in my sig jets are 50 and 150 needle is on the third clip. Im running 91 octane gas and 32:1 mix . iv been messing around with the needle but not the jets yet. Thar seems to be an excessive amount of oil on my plugs and coming out of the exaset in between the jug and expansion chamber and I don
  5. Ok 2 stroke gurus I need some more help I just got my freshly ported cylinders back and I was wondering if I should port out my pistons to match my intake? If not y, would taking material out of the piston skirt damage the structural integrity of the piston?
  6. can i just cut off the back tab and use the front one is it in the corect place?
  7. Ok so I need some help! I finally got my a arms in and I need too know if I can use one of the stock
  8. hears mine after about 5 hrs. i think it looks ok but my cylinders are kicking my @$$ i think im going to do a 2 stage pc on them instead candy red over metal fleck silver. My frame and spindles will match.
  9. I got my first banshee about 4 months ago and started a full out rebuild on it. I started with the moter. Picked up some 30mm PWK
  10. if you look at the first link u will see the part im interested in "This thing is actually titled and registered as a passenger vehicle, so you can ride it Coast-to-Coast on Interstate 80 if you wanted" thats the cool thing about that shee the rest is sweet but ivc seen 10x cooler bikes on hear. u guys have amazing quads
  11. check it out #1 #2 Im not saying their claims are by any means credible but it gives me some hope. I just want to be able to cruse to the trail and be legal, but taking the old shee to work once and a wile would be bad @$$ to!!!
  12. Does anybody know how you can go about making a four wheeler street legal?? And register it as a passenger vehicle??
  13. ill give ya $35 pm me thanks
  14. ???? U tell me found a sweet deal on works shocks for a rapter will thay be way stiff on a shee or whut???
