black sunshine Posted November 14, 2006 Report Posted November 14, 2006 Thought this was an appropriate forum, I ride mostly trails. Going to shell out some greenbacks for new tires. Going with 20's in back, my question is do I want 21,22, or 23's for the front? Dont know and dont want to buy the wrong size, thanks!! Quote
Bandit Posted November 14, 2006 Report Posted November 14, 2006 thats a good question...i have 21's in front and 20's in rear and seem to work good. But not really sure if its correct Quote
derfnigel Posted November 14, 2006 Report Posted November 14, 2006 thats a good question...i have 21's in front and 20's in rear and seem to work good. But not really sure if its correct my front's are 23" kenda klaws and i got 22" mudlights s in the back Quote
black sunshine Posted November 14, 2006 Author Report Posted November 14, 2006 So 1" bigger in front is the way to go? I thought that judging by the stock setup but I was pondering having some 22" rears at some point for springtime riding or nastier trails, but I dont want to buy another set of front tires just for those special occasions. Wanted to cheat the gap a little but the 20's would stay on the back for the majority of the year. Quote
4strokessuck Posted November 16, 2006 Report Posted November 16, 2006 Raz'r 21/7/10 Front. Raz'r II 20/11/9 Rear. It's what I got and is stock tire size. P.S. Changing tire size on the rear will change your gearing. Quote
mavbike Posted November 16, 2006 Report Posted November 16, 2006 Thought this was an appropriate forum, I ride mostly trails. Going to shell out some greenbacks for new tires. Going with 20's in back, my question is do I want 21,22, or 23's for the front? Dont know and dont want to buy the wrong size, thanks!! I trail ride only. 21" Kenda claws on front and 22" Kenda Bear Claws (good mud tire) on rear. Since a lot of the trails I ride are 4x4 ruted up,,,the 22" on the rear helped a lot. They did make a big difference in gearing though (have 13T front spocket on the way). Had 18" on rear when I got it and I was constantly dragging the ground. I like this set-up much better. You can run whatever size difference you want. The only thing is the front to rear ballance. Bike was already set-up with TCS shocks when I got it. Before changing tires, I measured frame height with me on it, front and rear. I think the rear was like 1/4" higher. After putting on the new tires, I adjusted rear pre-load to have the same 1/4" difference, front to rear. That way the weight bias would be the same. Sounds picky, but I really liked the way it handled when I got it,,,,so I just wanted to try and keep it the same. I did notice the new/bigger tires, are heavier. The bike is also just a little more tippy, but some of that may be new tires, good tread, better traction, not just being higher off the ground. Hope that helps a little?? :biggrin: Quote
black sunshine Posted November 17, 2006 Author Report Posted November 17, 2006 I trail ride only. 21" Kenda claws on front and 22" Kenda Bear Claws (good mud tire) on rear. Since a lot of the trails I ride are 4x4 ruted up,,,the 22" on the rear helped a lot. They did make a big difference in gearing though (have 13T front spocket on the way). Had 18" on rear when I got it and I was constantly dragging the ground. I like this set-up much better. You can run whatever size difference you want. The only thing is the front to rear ballance. Bike was already set-up with TCS shocks when I got it. Before changing tires, I measured frame height with me on it, front and rear. I think the rear was like 1/4" higher. After putting on the new tires, I adjusted rear pre-load to have the same 1/4" difference, front to rear. That way the weight bias would be the same. Sounds picky, but I really liked the way it handled when I got it,,,,so I just wanted to try and keep it the same. I did notice the new/bigger tires, are heavier. The bike is also just a little more tippy, but some of that may be new tires, good tread, better traction, not just being higher off the ground. Hope that helps a little?? :biggrin: Quote
Bandit Posted November 17, 2006 Report Posted November 17, 2006 my front's are 23" kenda klaws and i got 22" mudlights s in the back I would like to see a pic of mudlites on a banshee...i was looking at them they look cool. Quote
hawk363 Posted November 27, 2006 Report Posted November 27, 2006 i got a set of gators on the back of my machine, they are def. heavier and throw the balance off a bit i think but they are good for trails and i love the look of the tread pattern. think im ditchin them next summer though for something more sporty Quote
owmyeye Posted November 27, 2006 Report Posted November 27, 2006 20" in the rear, 21" in the front. I mostly trail ride as well and haven't had a problem. Quote
atvaddiction Posted December 6, 2006 Report Posted December 6, 2006 i have 23 fronts and 20 rears but i think i wont rather have 21 or 22 in the front. 23 are to heavy and dont handle good. Quote
micorps1 Posted December 13, 2006 Report Posted December 13, 2006 When i set my banshee up for harescrambles, i had input from andy lagzdins, a pro rider on the gncc when i was ordering my carbon fiber Hiper Techs. So i went with ITP GNCC series 22x7-10 on the front and ITP XCR 20x11-9 in the rear. I also dropped the front sprocket 1 tooth. The taller tire gave me alot more clearance in the front and are light enough to hit alot of the jumps on the MX tracks when they incorporate them into harescrambles. I just ran a 3-hour buddy harescramble at Tomahawk, WV on Sunday and had no mechanical issues. 6 laps on a 8 mile course with some very technical sections with nothing but rocks and boulders and 4 miles of motocross. My banshee didnt want to nose dive or anything. Quote
dishman Posted December 15, 2006 Report Posted December 15, 2006 I would like to see a pic of mudlites on a banshee...i was looking at them they look cool. if i was going to run mudlights i would do the new mudlight s/p 20/11/9 they weight in at 17 pound and holeshot xcr weights in at 16.5 so your not going to gain that much weight Quote
samdust Posted December 15, 2006 Report Posted December 15, 2006 Raz'r 21/7/10 Front. Raz'r II 20/11/9 Rear. It's what I got and is stock tire size. P.S. Changing tire size on the rear will change your gearing. on the measurements like 20-11-9 that means ^height of tire ^width of tire ^rim diam. right? so i got 20-10-9 now can i get away with 20-11-9 i dont want to get new rims. Quote
dishman Posted December 15, 2006 Report Posted December 15, 2006 on the measurements like 20-11-9 that means ^height of tire ^width of tire ^rim diam. right? so i got 20-10-9 now can i get away with 20-11-9 i dont want to get new rims. yes you can use the rim you have now Quote
